than their "artificial" counterparts such as teflon, polyprop, etc.
What are your thoughts on this.
Laymen's talk!
Personally I prefer natural materials. But I've always been struck by the metaphysical relationships between a material and its "sound." Like tubes sound "warm," solid state sounds "hard," silver sounds "bright," etc.
It seems pretty clear that there's some psychology going on here.
se
se
se
Some of my tube builds have sounded harsh, my chipamp with Elnas in the supply warm, (some of) my silver wiring mellow. Help!
edit: Bas, if you could, what did you hear in the Teflons?
Sorry but this is absurd. Quality capacitors sound better, regardless of the technology. Polypropylen and Polyestirene are the ones with better reputation AFAIK.
But a better CIRCUIT DESIGN is much more important than the type of capacitors or resistor used.
It makes me remember of those audiophiles that buy things as "CD stabilizer rings" to make "sound more stable", or that they think that placing the turntable on a marble plinth will make the sound more "solid"... or that a wooden turntable arm will give an "organic sound", or that placing a CD under a hot bulb for 15 minutes before playing will give a "warmer sound"
Who said different?But a better CIRCUIT DESIGN is much more important than the type of capacitors or resistor used.
There must be some basis to it.
Hashimoto and Audio Note among others say they have tried various interleave insulation materials but they all find paper sounding better.
http://www.audionote.co.uk/articles/art_transformer_design.shtml
http://www.tube-amps.net/Technical_Aspects.htm
http://magneticcomponents.net/HearWhyBuyYourFenderandMarshallReplacementTransformerFromUs.html
IMMO dielectric is dielectric. Period.
Silk, paper, and dried cocodrile skin is dielectric. Polypropylen is dielectric.
But polypropylen caps cost X. Paper caps cost 10X.
Do you think that natural=expensive=better? No, I don't think so.
If a teflon cap sounds bad, you are using a bad cap. If a paper-snake oil cap sounds bad, you are using a bad cap.
Compared to the massive variation in speaker impedance over the frequency range the dielectric of the cable is insignificant.
This sounds like the old "more expensive must be better" brigade at it again !
Massively expensive is usually very little better than expensive.
Why would a pcb need professional layout? The lines are only 1/200 Ohm. Maybe ESR and ringing could possibly play a role here?
I also know that paper tastes better than polypro.
Actually each dielectric is different if it is made from a different material.IMMO dielectric is dielectric. Period.
Nomex (also used in transformers as layer insulation) is about 20X more expensive than paper. Paper is also cheaper than teflon or most other dielectrics commonly used.But polypropylen caps cost X. Paper caps cost 10X.
Where is the brigade? Where did I mention costs?This sounds like the old "more expensive must be better" brigade at it again !
Besides I'm not trying to prove a point here. I'm asking for your opinions or experiences on the matter.
It makes no difference that matters in my experience.
I use 13 amp mains cable for my speaker leads and have no problems.
Its cheap and sounds just fine.
I used CAT5 network cable also cheap and sounds just fine. (Teflon dielectric )I use 13 amp mains cable for my speaker leads and have no problems.
But I have silk coated speaker cable that I one day want to try one day.
dielectrics
wonder why?? maybe if they were "enabled" in a certain way, they'd sound even better, no?
Or maybe "artificial" sound better with electronic music and "natural" with acoustic
Hey! Do you know how to do that to caps?maybe if they were "enabled" in a certain way
Dielectric materials do have differing properties when viewed from an E Field perspective. Dielectric constant provides a pretty good look at what charge state must be held during an E Field moment and one of it's components is threshold. Plastics with high constants, Kapton and the like, usually have a slow acceptance and discharge rate and so do tend to strip some of the information that would cue our brain to illusions of space. Cotton and paper have a low dielectric constant and are noted for not loosing this low level information. Teflon theoretically should be very good at this too, however it also makes my nerves crawl after a bit and it always seems noisy.
For signal transformers the family of anhydrous nylon papers seem to be the least intrusive, with fine retention of low level signals during the E Field moment and yet still have enough dielectric withstand and resistance to corona, to be used in relatively high voltage situations (800 vac). Unfortunately the material is worthless as a capacitor dielectric.
Bud
Bud
- Design & Build
- Parts
- Natural dielectrics (in caps and wire) like silk, paper and cotton sound more natural
