I've got a Kenwood KDC-V7017 and i need a replacement part. The part is what the faceplate clicks onto and rotates it around when you eject a cd and/or turn it off. It looks like a thin rectangular piece of metal with a swiveling arm that connects to each end longways. The plastic plate that is glued to the back is all you see when the unit is switched off. The arm on mine is snapped in two but i think this might be one part number for both pieces. I don't really need the plastic plate; i can glue on the one i have. If I can just find the part # I can order it online.
