Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Shanti Dual LPS 5V/3A , 5V/1.5A
Old 3rd July 2020, 06:26 AM   #1581
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by cdsgames View Post
First draft of the manual , we are incorporating all drawings on power connection on the second draft
Are the default settings also your prefered ones?
F5 - SSLV 1.3 Ultra BiB
Old 3rd July 2020, 07:30 AM   #1582
reelben is offline reelben  Netherlands
dvb , I will tell you tomorrow
reelben ..thx you
Try both sync and asynch . Async is at 1 (lowest setting)
I play asynch now... and I want not to much change in the Signal
Or Everything off.. I try later.... change it.
It plays great and beautiful.
It's a good dac for the value.
Thanks I'm happy
Old 3rd July 2020, 08:20 AM   #1583
cdsgames is offline cdsgames  Canada
we measured 650ma with music playing
Old 3rd July 2020, 08:36 AM   #1584
Thanks a lot.
Old 3rd July 2020, 09:17 AM   #1585
Updated Rev manual with PSU connection and earthing diagrams
Old 3rd July 2020, 09:24 AM   #1586
No.
Old 3rd July 2020, 11:10 AM   #1587
zzt231gr is offline zzt231gr  Greece
Hello to all.
I am interested in Allo Shanti and I started reading this thread but I see that it is used for other devices,too.
Is there a place or posts where I can read reviews of sound and built quality of this psu?
Has anyone used it with Chord Qutest?i already tried MCRU lps but it souded a little bright...
Thank you.
Old 3rd July 2020, 11:33 AM   #1588
There are thousands of people using Shantis and posting on all forums , but no I dont have a specific link
Old 3rd July 2020, 11:38 AM   #1589
Markw4 is offline Markw4  United States
That dac is a little bright. Power supply can only do so much.
Old 3rd July 2020, 01:19 PM   #1590
cdsgames, Its been awhile since I looked inside Shanti, but I have a new one here that needs to have its output voltage tweaked up. It appears to come preset to about 4.5v on each supposedly 5v output. Don't recall which are the correct adjustment pots and which are the don't touch pots. However, the pots near the outputs have the screws glued into position, and the pots closer to the middle of the board don't have adjustment screws glued into position. Since there doesn't seem to be a Shanti manual describing the pots that I can find, before I start trying to start reverse engineering the thing which pots do you recommend to turn? Thanx.
Shanti Dual LPS 5V/3A , 5V/1.5AHide this!Advertise here!
Buffer with Dual N-Ch Jfets and Dual Power Supply vdi_nenna Pass Labs 64 22nd April 2019 07:19 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 12:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 06:26 AM
Dual turntable dual cs741q help needed steelyjoe Analogue Source 0 8th August 2010 03:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
