Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 13th July 2019, 01:40 PM   #2821
amigo1 is offline amigo1
amigo1's Avatar
Default Debian 10 Buster for Beaglebone Black!
Originally Posted by miero View Post
Here you can disscuss and report issues with Botic Linux driver available at http://bbb.ieero.com/
Hi Miero! Maybe you can help? Using Debian 10 Buster is a good solution for Beaglebone black software upgrade!
Old 18th July 2019, 07:14 AM   #2822
amigo1's Avatar
List of Linux OS used for Beaglebone Black for audio tasks.
1) Debian 10.0 2019-07-07 4GB SD IoT image Buster
BeagleBoard.org - latest-images
2) volumio-2.194-2017-06-11-bbb.img.zip
Beaglebone Black rev C - сетевой плеер - Arduino и Raspberry Pi - Форум по радиоэлектронике
3) RuneAudio 0.2-beta
Download RuneAudio from SourceForge.net
4) ArchLinux
Support for Botic Linux driver
Filebin
Old Yesterday, 03:11 PM   #2823
Blitz is offline Blitz  Germany
Is this the official uEnv.txt of Botic 7 ? There are tons of other, non-botic related entries in there....
platform-bbb/uEnv.txt at master * volumio/platform-bbb * GitHub
As this comes from Miero, I giess this entry is meant for Hermes/chronus:
snd_soc_botic.serconfig=MDR-
Can anyone using BbB and Hermes confirm that ?
From Miero's page:
"Emulation of mute pin on some of 1-4 data pins:
- kernel option snd_soc_davinci_mcasp.mute_pin
- file /sys/module/snd_soc_davinci_mcasp/parameters/mute_pin
which can be updated while system is running, but change
will be applied on the next start of playback
Supported values for mute_pin:
-1 ... mute pin functionality is disabled
or these additive numbers:
+ 1 ... signal mute on pin 0
+ 2 ... signal mute on pin 1
+ 4 ... signal mute on pin 2
+ 8 ... signal mute on pin 3
+ 16777216 ... invert the mute signal
For example (stereo playback of I2S/DSD on TPA Hermes-BBB):
$ echo 12 > /sys/module/snd_soc_davinci_mcasp/parameters/mute_pin
$ echo MD-- > /sys/module/snd_soc_botic/parameters/serconfig
Two pins are needed, because Hermes-BBB switches pins 2 and 3 when I2S/DSD mode
is switched. After playback start/stop there should appear a mute pin on D5
output pin of Cronus."
I am not sure what to put where as I am not a Linux expert...please help. Where need the $Echo commands get intoand how are they related to uEnv.txt.
Old Yesterday, 05:46 PM   #2824
ChrisMmm, with new driver you need to use different data pin (P9_30), or set kernel option snd_soc_davinci.sermask=4 ... or 12 if you want 2ch DSD too.
twluke, lrck position is fixed on BBB. The Botic cape will remap/route pins to correct positions. That's why there is I2S/DSD format switch pin.
Have I missed something ? Where has this parameter been documented ?
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
