Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 17th November 2016, 03:31 AM   #1951
adeveza is offline adeveza  United States
Has anybody successfully boticized volumio? if so, can anyone point me to the "how to" link please? very much appreciated.
Alex
Old 18th November 2016, 07:37 AM   #1952
flowerpot is offline flowerpot  Singapore
I am not able to flashed the image to the eMMC, not sure what I did I wrong ??? Tried to re-download the image still does not work... the flash sequence does not start... I try the NAA image the leds sequence shows it's flashing the eMMC... but Ray's image the leds just blink on the first led... any advice ?? I also wanted to try a fresh install of Debian stretch but I could figure it out the correct way to do it... any ideas ?? Thanks
Originally Posted by nautibuoy View Post
The new image seems to have uploaded successfully.
Just a note to make people aware that the image will flash your eMMC at first boot so you may want to back up any current image that is of value to you.
Having copied the image onto your uSD, insert it and boot from the uSD (hold the boot switch down on the BBB for a few seconds initially). The image will be flashed to the eMMC (takes about 10mins or so). On completion, power off, remove the uSD, and restart.
Login/password are debian/temppwd.
Ray
Old 18th November 2016, 05:22 PM   #1953
pixelpusher is offline pixelpusher  United States
flowerpot,
I downloaded Ray's image yesterday (Thank You, Ray) and tried in in my BBB.
I had the same experience that you did. Flashing the eMMC did not occur. Being a bit perplexed by this today I did a bit of research and found the following instructions from this web page; debian - Unable to Flash eMMC from SD Card BeagleBone Black - Stack Overflow
Did you remember to remove the "#" at the beginning of the line cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh ? To make this edit, which will cause the SD card to automatically flash any bbb you turn on with the SD card in it, you just need to follow these steps.
1. Connect your bbb to a power source (USB or DC work equally well)
2. Power off the bbb by pressing the power button.
3. Insert your SD card.
4. Power the bbb on.
5. Log in to SSH (I like putty for this) with port 22 and IP 192.168.7.2
6. execute: cd .. sudo nano boot/uEnv.txt
7.navigate to the line #cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh at the bottom of the txt file.
8. Delete the "#" at the beginning of the line.
9. control+x then "y" then "Enter key" to save your change and exit the txt file.
10. Reboot the BBB and the SD card should automatically flash to your BBB which will be indicated by the LED's following this pattern for (in my experience) about 10 minutes. LED pattern: 1-2-3-4-3-2-1-2-3-4-3-2-1-2-3-4-3-2-1... etc..
I took a look at uEnv.txt in Ray's image and it does indeed have that line commented out.
Personally I would rather not flash my eMMC so I will leave it as it is.
Old 18th November 2016, 05:26 PM   #1954
By the way, Ray's image is Debian 8.5 which is "Jessie"
Old 18th November 2016, 06:23 PM   #1955
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Yes sorry, my bad, I forgot to mention before that the current image needs to have the uEnv.txt edited to flash the eMMC. The earlier image had the flash enabled but I thought people would prefer to choose but then forgot to post anything about it.
Anyway, hope you enjoy.
Ray
Old 24th November 2016, 04:19 AM   #1956
DragonWar is offline DragonWar
Originally Posted by mikelangeloz View Post
I've prepared the bbb scripts on the repo,
so you can clone it and start building the images (I think it will ease up your work...)
There is a new repo for the bbb platform files:
https://github.com/volumio/platform-bbb
But during development you can just move over the files in the script without using it...
You can see the new scripts for bbb:
https://github.com/volumio/Build/com...fc3b7187b845a5
They should be pretty straightforwarding, but I've added some comments inside to guide you a bit...
After you've set up your dev environment (I suggest a debian one, but also ubuntu will work but you need to edit multistrap a bit, see the readme).
just launch :
./build.sh -b arm -d bbb -v 2.001
Let me know!
mi
Hi mikelangeloz,
Thank for your great work.
I success build the image of volumio 2 for BBB but when I install in SD Card and it's seem not running ( it's back to default OS of beaglebone). I will check the output of console later.
And I have another issue is when using BBB with Volumio 1.5 then the I2S output is only 48kHz ( also when I play with 192kHz) and I don't know how to change it's. It's also always 32 bit per sample in oscilloscope and sample frequency is 48kHz.
Can you teach me how to see what happen here by using SSH?
Thank a lot
Old 25th November 2016, 05:17 AM   #1957
nautibuoy's Avatar
Hi miero. Just wondering if you have any update regarding my request for a mute trigger to be exposed on the BBB headers by Botic.
You may recall, I would like the ability to trigger a mute relay (or similar) with a DSD-only decoder (such as the Signalyst DSC1) which can be prone to pops/clicks during codec changes.
If the header pin used isn't one isolated by Hermes I can add my own isolation.
Cheers
Ray
Old 25th November 2016, 01:53 PM   #1958
linuxfan is offline linuxfan  Australia
I just booted up botic v4 for the first time. Upgraded to v7rc1-larger buffers.
Changed network config to static IP.
Now on to mounting my NAS as a cifs share -
Originally Posted by miero
1b) mount remote storage into /data directory
mkdir /data/remote
nano /etc/fstab
# windows share directory (cifs)
//IP_ADDRESS_OR_HOSTNAME/REMOTE_DIRECTORY /data/remote cifs user=USER_NAME,pass=PASSWORD,cache=none,gid=audio
I would prefer to mount my network share as /mnt/nas
Obviously I would then change the MPD configuration to set this location as my music directory ...
... but would I be missing out on anything else by not using the /data directory?
ie. are there any other features of botic, such as internet streaming for example, which point to /data??
Thanks.
Old 25th November 2016, 03:04 PM   #1959
ichiban is offline ichiban  United States
The tubes are HOT !!!
ichiban's Avatar
Support for Botic Linux driver
Default v5 vs v7rc1
Could someone comment on the differences between versions v5 and v7rc1.
What has been added or improved?
Does it make an improvement, sound wise?
Thanks, Ichi
Twisted Pair ESS9038>Mercury>B1KORG pre>F4>SEAS-THOR spkrs
Old 25th November 2016, 11:37 PM   #1960
twluke is offline twluke  Japan
Thanks, Ichi
You might want to check this comment by miero for the detailed info on v7rc1.
For a while I've been using this version without any problems. I2C control of B3SE from BBB-Hermes works fine. The SQ via MPD is quite stable. Currently I'm running this version on a debian stretch distro with newly compiled MPD-0.18.23-dsd-rt and MPD-19.19 (patched with realtime option), both capable of playing native DSD512 sources.
Also, this version with debian stretch works fine as an NAA (network audio adapter for HQ player) as suggested by miero and Ray and also as a RoonBridge for Roon library. I'm using these options and MPD alternatively on a single debian system.
Support for Botic Linux driverHide this!Advertise here!
Thread Tools
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
