Newbie's 1st Amp, comments please.
Joel,
OK, to clarify, I didn't mean that a valve with high gain is a bad thing. It's just that in the designs I've done in the last 8 years, I have not found a place for such a device.
Those amps have been low or no feedback.
I was speculating that others who use similar design lines might have found the same thing.
I have no grudge against 12AX7's;)
Hi everyone,
I like this forum idea!
Much better response than I expected.
I don't even have to ask questions and I get answers to them.
fdegrove - Frank is it?
The ciruit you provided is exactly what I had in mind.
Where did you find it?
I will check again later, then I will go home for the weekend and ponder these suggestions.
And I will see if I can come up with some sensible questions for next week.
Some questions
Hello :)
Power Supply
There are many varied opinions.
I think that the general consensus is that if you have a power supply capable of supplying the demands of the amplifier, that is suitably filter with a good LC filter, it doesn't matter what you use.
So I think I will use diodes, a pi type filter (CLC) with a reasonable capacitor on the output.
I have read in another post about 'stand-by' or 'delayed turn-on'
and I get the impression this is not good.
What about a slow start circuit?
Tubes
Matched pairs - pros & cons?
Are they nessesary with fixed bias?
I intend to use fixed bias on the last stage.
diyAudio Senior Member
Joined 2002
DELAYED RESPONSE...
When you choose silicon rectification a delay on the B+ wont hurt
(say 10 secs).
A tube rectifier does that automatically though.
However,what is just as important to preserve the tubes it to provide for a quick discharge path of the PSU when turning OFF.
Otherwise the same problem occurs!
That is assuming you want to preserve the tubewildlife....:D
Cheers,;)
