Photo Gallery
Photo Gallery
Old 19th August 2019, 01:25 AM   #9081
kissabout2002 is offline kissabout2002  Italy
Originally Posted by torrence View Post
A GU-50 SET driven by a 6EM7. I was trying to make something small like the Dynaco ST-35. I started working on this amp in Spring of 2012 after some threads by Wavebourne. It has only taken me 7 years to finish it...
Wowww very good looking amp, for sure it takes you long time but the care on details is outstanding, I like the combination of lamination and aluminium very very nice congrats so enjoy the music
Old 19th August 2019, 09:02 AM   #9082
JoeAlders is offline JoeAlders  Netherlands
Perhaps a stupid question: What are these (for me) strange looking frames around two of the tubes? Could not see if it are tubes though....
Old 19th August 2019, 09:11 AM   #9083
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
That's a special frame that keeps the tube in place mechanically, so installed in a MiG-fighter the tube will nicely sit in place, whatever the airplane does. Besides, the tube can also be pushed into the socket in different ways and the frame has a guide that steers the tube into the right position. There are more advanced sockets like this one. You can see the slot at the bottom of this pic. The tube has a ridge that fits that slot.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 19th August 2019, 09:20 AM   #9084
Thank you very much soundbrigade for your explanation!
Old 19th August 2019, 09:35 AM   #9085
I would like to add that there are sockets without the frame, and using them you must be very observant to stick the tube into the socket correctly, else you will kill the tube instantly - been there, done that.
Here's a "naked" socket and you see the "key". Missing that and you will loose a tube.
Btw the GU50 are wellknown for their sound qualities and can be found pretty cheap here and there.
/Magnus
Old 19th August 2019, 11:17 AM   #9086
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
Originally Posted by hellotron View Post
Hi. In the meantime I committed such a "toddler". Includes: Digital FM radio, Bluetooth, EQ, micro SD / USB reader, aux input, manual tone adjustment. Audio amplifier on 5670 and EL95 tubes, power output 2 x 3W. The whole is controlled from the remote control.
nice project! you should start a new thread and tell folk more about it.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th August 2019, 02:15 PM   #9087
+1
Old 2nd September 2019, 09:58 PM   #9089
Shef is offline Shef
Shef's Avatar
Old 3rd September 2019, 12:03 AM   #9090
Scorpion is offline Scorpion  Canada
Ok, here they go...
Some of the OUTSIDE first
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
