Spark plug wire for tubes with a top cap?
Old 16th September 2020, 05:17 AM   #21
H713 is offline H713  United States
H713's Avatar
Another option would be to use some coax with a PE (NOT FOAM) dielectric. Something like RG-58 would be a nice size. If you ground the shield, then you have some shielding (that may or may not matter) and an additional safety feature. Otherwise, strip the outer jacket and the shield off and use the inner conductor and dielectric as HV wire. Not sure about RG-58, but RG-213 with a solid PE dielectric can take something like 60 kV without arcing over. I think it's rated for like 10 or 20 kV, but lots of companies use it for HV power supplies.
Old 16th September 2020, 05:17 AM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by jjasniew View Post
Perhaps if the tube is running class A, the copper oxide micro diodes wont matter much...
Perhaps
Mythical copper microdiodes will do NOTHING to sound, even if they exist, because each and every one of them will be surrounded by ... um .... "copper", so it ill be shorted anyway.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 16th September 2020, 08:24 AM   #23
6A3sUMMER is offline 6A3sUMMER  United States
600V wire? No!
An 807 plate @ 350V may swing up to 700V (or more).
Just sayin'
Old 16th September 2020, 08:46 AM   #24
kostasde is offline kostasde
You may use a high voltage cable from neon tubes. It is silicone with more than 20 kilovolts and is flexible
Old 16th September 2020, 11:33 AM   #25
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by 6A3sUMMER View Post
600V wire? No!
Just sayin'
It's close to being over spec but: 600VAC cable is rated to 1000V DC (or Peak) (at least here 600V AC cable is rated 600V/1000V and US spec "Tri-rated" is similar IIRC.
CAT III DMM cable, also silicone, also the same story 600VAC/1000V DC or peak.
That being said, I have experienced insulation 'leakage" with CATIII wires and probes when measuring 550V DC + half wave rectification garbage, sparking probe tips at 100Hz!
So with that in mind, a "belt and braces" approach is always worth it. (Just not 10kV magnetoflex or anything carbon based, unless you are planning to heat the cable enough so that its resistance becomes acceptable)
We don't rise to the level of our expectations, we fall to the level of our training
Archilochus
Old 16th September 2020, 12:01 PM   #26
gerrittube is online now gerrittube  Netherlands
Solid PE innercable of RG213 is fine for high voltage. RG213 with the copper shield started buzzing with 9KV in one of my PSU’s many years ago, but never burned or sparked. I also made small high frequency capacitors, using 5 to 10 cm of RG213. These were OK for very high RF voltages (it’s hard to find a ceramic alternative). For voltages below 1000 VDC I would recommend the PE innercable of RG58.
Regards, Gerrit
Old 16th September 2020, 03:04 PM   #27
Windcrest77 is offline Windcrest77  United States
There must be a high voltage project fad amongst nerdy tech hobbyists these days, 10, 20 and 30 kV silicone wire is very cheap and plentiful on Amazon. Depending on the hole size on my top caps I'll probably get a few rolls of different diameters of this. Around .50 cents a foot.
My earlier post had a link.
Old 17th September 2020, 01:06 AM   #28
PRR is offline PRR  United States
PRR's Avatar
600V wire? No! An 807 plate @ 350V may swing up to 700V (or more). Just sayin'
A coat of paint will stop 300V. "Any" plastic will stand more, SHORT-term.
Insulation breakdown is really a gradual thing (unless you go crazy with voltage). All insulators WILL break down, some day. Faster with more voltage. "600V" wire is good for appliance or building for decades. If you use it in a 400V amplifier, it will last longer than you, even if it kicks to 800V on musical peaks. And Hi-Fi does not kick that high ALL the time. (Even overdrive guitarists take breaks.)
Old 17th September 2020, 06:49 AM   #29
I am never sure of insulation.
Example, I will not wrap my hand around an active spark plug wire.
I do not want to test the insulation.
But even more than that, I do not want to test the action of the capacitive reactance as it charges up during a very fast rise transient.
How many have ever tried that?
Old 17th September 2020, 07:08 AM   #30
lcsaszar is offline lcsaszar  Hungary
One has to consider aging, too. Plastic insulators can become rigid and brittle after the plasticizer components evaporate after a couple of years. Heat and UV radiation will speed up this process. If you bend such cable, there will be cracks on it, and the conductor will be exposed.
Silicone is an exception, and teflon also (I think). I use a teflon insulated silver plated copper wire, pulled in a transparent teflon tube.
Spark plug wire for tubes with a top cap?Hide this!Advertise here!
Are 6L6 Metal tubes plug and play Duke58 Tubes / Valves 11 18th September 2020 11:42 PM
Polarize plug, 3 wire or keep as is Tommyboy60 Tubes / Valves 17 3rd June 2020 12:07 PM
FS: Dynaco ST70, RUby EL34 tubes, Biased, Plug&Play baco99 Swap Meet 2 10th May 2018 10:23 PM
240/300 Ohms balanced IEC FM-Plug for flat Dipole Wire and for Disass'y e. g.Quad FM3 tiefbassuebertr Analogue Source 13 4th July 2014 08:56 PM
Good wire and plug for DIY power cord lovemov Parts 0 19th December 2003 07:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
