What can I do with them? 4x 1L4, 1x 6AQ5, 3x 6BQ5, 1x 6SN7
I will post a simulation of the 1x 6SN7 + 2x 6BQ5 stereo amp in the following evenings.
I think I can use 2x 1L4 for a stereo preamp (keeping two as spares), or one 1L4 and one 6AQ5 for a small guitar amp.
Any other suggestion is very welcome!
So this can be the SE amp with 6SN7 and EL84.
PS the pmosfet on the cathode is not the right model.
This is the simulation with 2Vp at its input, on 8 Ohm:
Code:
Harmonic	Frequency	 Fourier 	Normalized	 Phase  	Normalized
 Number 	  [Hz]   	Component	 Component	[degree]	Phase [deg]
    1   	1.000e+03	8.057e+00	1.000e+00	   -4.83°	    0.00°
    2   	2.000e+03	1.954e-01	2.425e-02	 -104.07°	  -99.24°
    3   	3.000e+03	9.741e-02	1.209e-02	    0.29°	    5.12°
    4   	4.000e+03	7.879e-03	9.779e-04	   67.47°	   72.30°
    5   	5.000e+03	2.293e-02	2.846e-03	  172.02°	  176.85°
    6   	6.000e+03	3.782e-03	4.693e-04	  -95.02°	  -90.19°
    7   	7.000e+03	7.546e-03	9.365e-04	   -9.88°	   -5.05°
    8   	8.000e+03	2.623e-03	3.256e-04	   95.77°	  100.60°
    9   	9.000e+03	2.303e-03	2.858e-04	  159.79°	  164.62°
Total Harmonic Distortion: 2.728697%(2.729385%)
Here it is an update on the SE amp now with different polarization for the 6SN7 and EL84 with 6k6 Ra load. Output is 8 Ohm:
Code:
.step vin=0.2
N-Period=1
Fourier components of V(output)
DC component:-0.00395607
    1   	1.000e+03	8.301e-01	1.000e+00	   -2.52°	    0.00°
    2   	2.000e+03	2.102e-03	2.532e-03	  -98.62°	  -96.10°
    3   	3.000e+03	7.846e-05	9.452e-05	 -177.36°	 -174.84°
    4   	4.000e+03	1.060e-04	1.277e-04	    1.05°	    3.57°
    5   	5.000e+03	3.280e-05	3.952e-05	    8.27°	   10.79°
    6   	6.000e+03	1.157e-04	1.393e-04	 -169.81°	 -167.29°
    7   	7.000e+03	3.552e-05	4.279e-05	 -151.26°	 -148.75°
    8   	8.000e+03	8.820e-05	1.062e-04	   21.78°	   24.29°
    9   	9.000e+03	7.929e-06	9.551e-06	  -60.16°	  -57.65°
Total Harmonic Distortion: 0.254335%(0.263054%)
.step vin=0.4
N-Period=1
DC component:-0.00520025
    1   	1.000e+03	1.660e+00	1.000e+00	   -2.52°	    0.00°
    2   	2.000e+03	8.327e-03	5.018e-03	  -95.74°	  -93.23°
    3   	3.000e+03	1.154e-04	6.954e-05	   -3.33°	   -0.82°
    4   	4.000e+03	2.119e-04	1.277e-04	    0.50°	    3.02°
    5   	5.000e+03	8.976e-05	5.409e-05	    7.74°	   10.26°
    6   	6.000e+03	2.065e-04	1.245e-04	 -168.61°	 -166.10°
    7   	7.000e+03	7.988e-05	4.814e-05	 -150.63°	 -148.11°
    8   	8.000e+03	1.788e-04	1.078e-04	   25.57°	   28.09°
    9   	9.000e+03	3.098e-05	1.867e-05	    1.27°	    3.79°
Total Harmonic Distortion: 0.502325%(0.506584%)
.step vin=0.6
N-Period=1
DC component:-0.00379257
    1   	1.000e+03	2.487e+00	1.000e+00	   -2.52°	    0.00°
    2   	2.000e+03	1.861e-02	7.482e-03	  -94.82°	  -92.30°
    3   	3.000e+03	9.160e-04	3.682e-04	   -0.46°	    2.06°
    4   	4.000e+03	3.221e-04	1.295e-04	   -6.34°	   -3.82°
    5   	5.000e+03	1.053e-04	4.235e-05	   11.02°	   13.53°
    6   	6.000e+03	2.749e-04	1.105e-04	 -172.64°	 -170.12°
    7   	7.000e+03	1.049e-04	4.215e-05	 -155.60°	 -153.08°
    8   	8.000e+03	2.502e-04	1.006e-04	   19.86°	   22.38°
    9   	9.000e+03	4.484e-05	1.803e-05	  -19.02°	  -16.51°
Total Harmonic Distortion: 0.749395%(0.752470%)
.step vin=0.8
N-Period=1
DC component:0.000216416
    1   	1.000e+03	3.313e+00	1.000e+00	   -2.52°	    0.00°
    2   	2.000e+03	3.296e-02	9.948e-03	  -94.06°	  -91.54°
    3   	3.000e+03	2.598e-03	7.842e-04	   -3.20°	   -0.68°
    4   	4.000e+03	3.763e-04	1.136e-04	  -16.25°	  -13.73°
    5   	5.000e+03	1.351e-04	4.077e-05	   18.34°	   20.86°
    6   	6.000e+03	3.766e-04	1.137e-04	 -170.77°	 -168.25°
    7   	7.000e+03	1.192e-04	3.598e-05	  163.92°	  166.44°
    8   	8.000e+03	3.926e-04	1.185e-04	   14.61°	   17.13°
    9   	9.000e+03	9.986e-05	3.015e-05	  -13.87°	  -11.36°
Total Harmonic Distortion: 0.998116%(1.000302%)
.step vin=1
N-Period=1
DC component:0.00655962
    1   	1.000e+03	4.134e+00	1.000e+00	   -2.52°	    0.00°
    2   	2.000e+03	5.100e-02	1.233e-02	  -93.66°	  -91.14°
    3   	3.000e+03	5.860e-03	1.417e-03	   -2.98°	   -0.46°
    4   	4.000e+03	6.389e-04	1.545e-04	  -64.91°	  -62.39°
    5   	5.000e+03	1.334e-04	3.228e-05	  121.63°	  124.15°
    6   	6.000e+03	2.842e-04	6.873e-05	  137.79°	  140.31°
    7   	7.000e+03	7.282e-05	1.761e-05	  -62.01°	  -59.49°
    8   	8.000e+03	3.042e-04	7.359e-05	   -8.22°	   -5.70°
    9   	9.000e+03	7.907e-05	1.913e-05	   10.99°	   13.52°
Total Harmonic Distortion: 1.241746%(1.243243%)
.step vin=1.2
N-Period=1
DC component:0.0146766
    1   	1.000e+03	4.951e+00	1.000e+00	   -2.53°	    0.00°
    2   	2.000e+03	7.226e-02	1.460e-02	  -93.36°	  -90.83°
    3   	3.000e+03	1.135e-02	2.293e-03	   -1.52°	    1.00°
    4   	4.000e+03	1.147e-03	2.317e-04	  -91.04°	  -88.52°
    5   	5.000e+03	5.505e-04	1.112e-04	  175.44°	  177.96°
    6   	6.000e+03	1.625e-04	3.283e-05	   72.22°	   74.74°
    7   	7.000e+03	2.246e-04	4.536e-05	   -5.44°	   -2.92°
    8   	8.000e+03	2.005e-04	4.050e-05	   39.43°	   41.96°
    9   	9.000e+03	1.609e-04	3.249e-05	   -1.64°	    0.89°
Total Harmonic Distortion: 1.477732%(1.478676%)
.step vin=1.4
N-Period=1
DC component:0.023313
    1   	1.000e+03	5.757e+00	1.000e+00	   -2.53°	    0.00°
    2   	2.000e+03	9.524e-02	1.654e-02	  -93.22°	  -90.69°
    3   	3.000e+03	2.155e-02	3.743e-03	   -1.95°	    0.58°
    4   	4.000e+03	2.623e-03	4.556e-04	  -96.29°	  -93.76°
    5   	5.000e+03	2.285e-03	3.968e-04	  175.22°	  177.75°
    6   	6.000e+03	5.535e-04	9.614e-05	   60.68°	   63.21°
    7   	7.000e+03	6.695e-04	1.163e-04	   -3.40°	   -0.87°
    8   	8.000e+03	1.137e-04	1.974e-05	  -26.57°	  -24.04°
    9   	9.000e+03	2.166e-04	3.763e-05	   15.44°	   17.97°
Total Harmonic Distortion: 1.697215%(1.697871%)
.step vin=1.6
N-Period=1
DC component:0.0300072
    1   	1.000e+03	6.547e+00	1.000e+00	   -2.53°	    0.00°
    2   	2.000e+03	1.166e-01	1.782e-02	  -93.07°	  -90.54°
    3   	3.000e+03	4.113e-02	6.283e-03	   -2.19°	    0.34°
    4   	4.000e+03	7.038e-03	1.075e-03	  -97.49°	  -94.96°
    5   	5.000e+03	6.727e-03	1.028e-03	  174.59°	  177.12°
    6   	6.000e+03	2.023e-03	3.090e-04	   71.40°	   73.93°
    7   	7.000e+03	1.686e-03	2.575e-04	   -7.16°	   -4.62°
    8   	8.000e+03	5.088e-04	7.772e-05	  -85.92°	  -83.39°
    9   	9.000e+03	1.207e-04	1.843e-05	   80.48°	   83.02°
Total Harmonic Distortion: 1.895480%(1.895898%)
.step vin=1.8
N-Period=1
DC component:0.0285851
    1   	1.000e+03	7.301e+00	1.000e+00	   -2.54°	    0.00°
    2   	2.000e+03	1.272e-01	1.743e-02	  -92.80°	  -90.26°
    3   	3.000e+03	8.231e-02	1.127e-02	   -2.60°	   -0.06°
    4   	4.000e+03	2.038e-02	2.792e-03	  -98.40°	  -95.86°
    5   	5.000e+03	1.944e-02	2.662e-03	  173.83°	  176.37°
    6   	6.000e+03	6.338e-03	8.681e-04	   73.88°	   76.42°
    7   	7.000e+03	4.724e-03	6.470e-04	  -10.28°	   -7.74°
    8   	8.000e+03	1.419e-03	1.944e-04	 -102.00°	  -99.46°
    9   	9.000e+03	7.279e-04	9.969e-05	  159.18°	  161.72°
Total Harmonic Distortion: 2.114000%(2.114095%)
.step vin=2
N-Period=1
DC component:0.00670644
    1   	1.000e+03	7.981e+00	1.000e+00	   -2.55°	    0.00°
    2   	2.000e+03	1.143e-01	1.432e-02	  -91.67°	  -89.12°
    3   	3.000e+03	1.714e-01	2.148e-02	   -3.05°	   -0.49°
    4   	4.000e+03	4.742e-02	5.941e-03	 -100.12°	  -97.57°
    5   	5.000e+03	5.301e-02	6.642e-03	  173.90°	  176.45°
    6   	6.000e+03	1.370e-02	1.717e-03	   69.51°	   72.06°
    7   	7.000e+03	1.456e-02	1.825e-03	   -8.13°	   -5.58°
    8   	8.000e+03	1.357e-03	1.700e-04	 -161.11°	 -158.56°
    9   	9.000e+03	2.772e-03	3.473e-04	  175.89°	  178.44°
Total Harmonic Distortion: 2.742556%(2.743101%)
