Ordering from Justradios.com
Old 29th June 2020, 03:19 PM   #101
astouffer is offline astouffer  United States
astouffer's Avatar
Pretty much any modern cap is going to be superior to what is being replaced. I guarantee that in a 50 year old radio you won’t hear a difference between a 10 cent cap versus a $10 cap. Buy 105c rated electrolytics and poly film caps for the rest. All the old low value pF caps should be fine. Replace the caps and enjoy the radio.
Old 29th June 2020, 03:41 PM   #102
Fjellreven is offline Fjellreven
What if its a more high end Model like huldra 7 connected to a decent sound card playing a flac file
Old 29th June 2020, 03:56 PM   #103
duncan2 is online now duncan2  United Kingdom
Fjellreven -- FLAC is compressed the audio WAV files I use are UN- compressed.
Huldra 7 Radio Tandberg Radio; Oslo, build 1963–
Even has a "Magic Eye " and stereo EL84 output
over 1000 Krona must be "upper class Norwegian "
Old 29th June 2020, 04:06 PM   #104
I have a seperate question why was almost every speaker made in norway back in the Day 4 ohm,for example the tandberg type 165 that was used in several tube radio's. I know its possible to make a 4 ohm tube radio, but when i search online everyone said you should use a speaker with No less then 8 ohms and the higher the impedance the better. i know that impedance changes depending on the frequency its Just that i was hoping to use some old 4 ohm 3 to 10 watt speakers with the tube radio's. I am aware i should use highly sensitive speakers though.
Old 29th June 2020, 04:38 PM   #105
astouffer's Avatar
Lol FLAC is lossless compression. A decompressed file is a bit for bit copy of the original. FLAC even does checksums to prove it.
Old 29th June 2020, 06:01 PM   #106
I would need some convincing Astouffer .
Old 29th June 2020, 06:07 PM   #107
Can i use 4 ohm speakers with tube amps. I want to use tandberg speakers with tandberg tube radio's and almost all of the tandberg speakers are rated 4 ohm.
Tandberg-høyttalere
If i could i would get hifi system 14 its 4 ohm but its very sensitive and also its got the right aestethic.
Old 29th June 2020, 06:31 PM   #108
The old original standard was 3 ohms and 15 ohms with some variation .
The old radios I have worked on were all lower than 8 ohms which is a comparatively "modern " impedance compared to very old radios and amplifiers .
Look Fjellreven only one thing counts the OUTPUT impedance of the output transformer not "what some guy told you " they obviously are referring to modern era amplifiers not old tube radios .
Even if it is 4 ohms a 3 ohm speaker will still work with it .
Why ? because the audio frequency is severely restricted in an AM radio and a lower end FM radio of that era will not allow full FM audio reproduction it will be able to receive the FM but it wont be "hi-fi " reproduction .
Later tuners were an improvement , remember its also got to do with the ability to demodulate the signal down to good quality reproduction in a cheap end old radio that's never going to happen.
Old 29th June 2020, 06:46 PM   #109
audiowize is offline audiowize  United States
Ordering from Justradios.com Send a message via AIM to audiowize
Dude, this is a 1963 table radio... The speakers and electronics will be designed to reproduce the vocal range and not much else.
Old 29th June 2020, 07:08 PM   #110
What if i connect it to something like this
Tandberg høyttaler Hi-Fi System 3
Im sorry but you are wrong if you were right then why did tandberg made hifi speakers that went into the 16khz range and remember this many tandberg product had seas parts for example the sølvsuper 7 deluxe had two seas tweeters that went into the 20khz range.
Ordering from Justradios.comHide this!Advertise here!
Justradios - Recent email problem VictoriaGuy Parts 0 26th February 2019 12:35 AM
Anyone ordering from THEL? Nisbeth Parts 0 6th April 2007 09:39 PM
Ordering a Charlize? onehotchili Class D 2 26th May 2006 06:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
