Yes.. that's the one
Do you have only the PCBs or do you also have a full set of tubes and transformers.
Remember that the bulk of the cost will be in transformers, then tubes.
Looking at the schematics it should be possible to modify / replace components and use as base for a Williamson topology type amplifier.
In fact, I am considering doing just that to a Music Angle KT88 amplifier. similar, but not identical to your boards. It fact it looks like MA has at least 3 different PCBs/designs of this specific amp using different tubes and topology.
Depending on your skills with electronics in general and tubes specifically you may be better off spending your money on a kit.
As for the modifications proposed by Mr. Lampizator, there are some good inspiratoin there. Personally I would apply all of these modifications without thinking twice or trice before soldering. Swapping in ECC88/6922 tubes and at the same time removing grid stoppers do not go hand in hand in my book.
