What you're asking is something that takes a book's worth of reading to even understand.
Because there are several parameters involved, and trust me, I'm not about to spend the time to type it all out.
If you're the average consumer, the usual and basic thing is to test for emission of tubes - a simple tester can do that.
In your case, you probably have a tube that's aged, or slightly defective in manufacture.
Get a new matched set and enjoy the music.
Alright, then. I did test the emission of the tubes...
The tubes are a couple hundred micromhos different. I would have thought that the tube with the higher transconductance would have been louder.
Don't want to cause any sore fingers, so I'll read some more. I have other tubes I can run with the amp. Thanks!
