Can I wire 2 amps in parallel
No, don't attempt this, or amplifier (and maybe speaker) damage will result.
If you build an outboard unity gain inverter stage, you can feed balanced signals to the two amp inputs, and connect one speaker between the two "hot" 8 ohm outputs. This makes the stereo amp into a monoblock.
But this would only work well enough with a 16 ohm speaker. These amps have just 8 ohm and 4 ohm outputs, but not the 16 ohm taps that would be used for bridging with a typical 8 ohm speaker.
I thought when bridging the amplifiers the load impedance would be halved so if I have 8 ohm speakers I would set output impedance on amplifiers on 4 ohm. I probably don't understand correctly.
I thought when bridging the amplifiers the load impedance would be halved.
It actually doubles, since the channels are in series, and out of phase.
So it skould be ok to use 4 ohm speakers then I will
have 8 ohm on amps outputs in bridge mode right?
No, just the reverse. In the bridge mode, you would connect either:
one 16 ohm speaker between the two 8 ohm taps
or
one 8 ohm speaker between the two 4 ohm taps
- Tubes / Valves
- Parallel amps wiring
