Beard P101
Hello. I have a Beard P101 power amplifier. Does anyone know the correct valve order of the preamp?. It uses e82cc, e81cc and e83cc, but I don't know the position of each one. I don't have the schema or service manual.
Thank you
It doesn't need too much work. It has a board to switch from half power to full power mode (see attached image) that doesn't seem original. It has a loose wire and it only works well on full power mode.
Yes, that is what I have in mind. The problem is to know how the original wires was wired. The power section is different from P100..
