The link would be useful I suppose.
Assembled 6N3 Tube Pre-AMP Stereo Hifi Buffer Preamplifier For Audiophile DIY
I would not buy it in the first place if you cannot get schematics and a reasonable answers from the vendor.The link would be useful I suppose.
Ebay has lot's of vendors that gives support don't support those that lacks support
The reason they can't tell you the output voltage is because it depends on the input voltage. They should be able to tell you the gain. Given the circuit diagram it should be possible to estimate the gain. Almost certainly it will have too much gain, unless it really is a buffer - in which case the gain will be close to 1.
- Tubes / Valves
- Output voltage query
