Recommended coax
Sorry if this has been addressed, and it's not really tube related, except that I'll connect it to tube gear. Anyway, I'm looking for recommendations for a good coax for interconnect cables. I bought some nice screw-down RCA plugs and I'm gonna try my hand at cable making. The plugs will accept up to 8mm diameter cable. Sources appreciated.
Raymond
I can recommend Belden, the two types i have used are,
Belden 89259 http://www.belden.com/techdatas/metric/89259.pdf , plain copper shield and conductor, Teflon insulation, 4.9mm overall diameter, 56.7pF/Meter. Only downside is its fairly rigid and inflexible.
Belden 1505F http://www.belden.com/techdatas/metric/1505F.pdf , tinned copper shield, plain copper conductor, PVC insulation, 6.1mm outer diameter, 55.7pF/Meter. Softer and more flexible than the above, also available in various colours.
Attached pics of both types...
Joined 2004
Belden +.
I use 89259 internal conductors (PTFE insulated) twisted each other in my unshielded interconnects.
Belden 1505 or 1694 is very good to DAC SPDIF interconnect (with 75 ohm RCA connectors - for example Canare RCA crimp plug-).
http://www.btx.com/default.aspx?page=item+detail&itemcode=BEL-1505A0021000
http://www.btx.com/default.aspx?page=item+detail&itemcode=BEL-1694A0065000
I also use Belden 1506a and 1695a cables for my measuring sets.
Formerly I used Mogami 2534 quad cables, but it's capacitance is a bit high.
I found the same, here are some measurements i got from various cables i had to hand.
Belden 89259 .75m = 47pf
Cambridge Audio Silver Reference .75m = 52pf
Cambridge Audio Qunex 99% OFC .75m = 104pf
Multicore cables (i.e. non coax)
NavShips 2x24g dual core shielded silver plated 1m = 54pf
Canare L-2T2S dual core shielded 1m = 78pf
Van Damme XKE quad core shielded silver plated 1m = 88pf
Canare L-4E6S quad core shielded 1m = 160pf
rif
Joined 2003
I use belden 1694a. I have also used belden 1505a in the past, but 1694a is my goto.
IIRC the 1505f mentioned above is very similar to 1505a, just more flexible, and 1695a is the plenum version of 1694a, but don't take my word for it.
Disabled Account
Joined 2010
Just read it; agree (with Evenh.)
Not the same tropic but, In the 1980's these blew away Audioquest quartz.
Its interesting to look at the construction if nothing else..I was very sceptical at the time so it was demonstrated to me..OK ears test.
I remember listening to some chord equipment with Epos 25's at the time..but I'll not comment. :D
It probably didn't help when I had listened to some Maggies about 5 minutes earlier..
https://www.google.co.uk/search?q=x...469n4WdyQIVi1sUCh1LvwRI#imgrc=kNr-AL7V2yEKLM:
M. Gregg
