This is my project for low cost, low voltage, simple, 2+2W Class A stereo tube audio amplifier.
Characteristics:
- Safe:
60 Vcc max (12+12Vac 35 VA line transformer + diode voltage doubler)
- Cheap:
less than 100 €
- Active Components:
V2 = PL504 (preferred) or PL500,
V1= ECC82 or 12FQ7 or 12BH7 (preferred)
- Easy:
it uses 220 Vac (110+110) / 24 Vac (12+12) 35VA line transformer as audio transformer, the low anode voltage (about 58Vcc) reduces the core saturation risk.
Note: for the best audio performances you may use a real audio transformer 600-800 ohm 5W (military surplus)
- Indestructible:
it withstands permanent output short circuit.
- Low distortion:
it uses negative feedback to reduce distortion.
Schematic (one channel audio + power supply for both channes and filaments):
ampli511 - Servimg.com - Free image hosting service
V2 pinout (anode = CAP):
V1 pinout:
Characteristics:
- Safe:
- Cheap:
less than 100 €
- Easy:
- Indestructible:
- Low distortion:
V1 pinout:
My first hybrid amp had a 12ax7 front end into a mosfet power amplifier.
The mosfet part had +/-45 volts supply so this 90 volts was also the supply (decoupled) for the 12ax7.
My first fully valve amp was a pair of el84's on the output with 12au7 as phase splitter and 12ax7 as amplifier front end.
This worked a treat.
My next was el34 based and was a bit more trouble to get working. I had hum and noise problems but eventually sorted them out. The PCB could have been better but I learned a lot from that project.
Characteristics:
- Safe:
- Cheap:
less than 100 €
- Easy:
- Indestructible:
- Low distortion:
V1 pinout:
hello ,
very good build , possible up voltage for up power out in audio , 100 V= si very good , me proto is based to your schéma
and very up in good choice to OPT at 250 V=
many thank Pilovis
Hi, really good project, i already try it on an breadboard, and works great
But on my project i want to add 2 things:
1º Bass, treble adjusts, not anything too much elaborated, just basic adjusts
2º A magic eye indicator with EM80 or EM84 tubes
But i dont know much about tubes operation, so wanted to ask if its possible to include this 2 things, and if there is a schematic with this two changes
Thanks in advance
Thanks in advance
What model Hammond or Edcor output transformer could be used?
Going by his use of 220v/24v transformer this would translate to 672 ohms primary with 8 ohms on the secondary.
- Tubes / Valves
- Your first DiY Low Cost/Low Voltage tube AMP
