Did you check the bias voltages? Assuming it's the kit from siliconray, there should be about:
> 120v on 6N1 plate
> 1.75v on 6N1 cathode
> 19v on 6P3P cathode
If everything checks out, try removing the feedback resistor.
If it's not the siliconray kit, a schematic would help.
> 120v on 6N1 plate
> 19v on 6P3P cathode
> 120v on 6N1 plate
> 19v on 6P3P cathode
Hi Ballpencil, Thanks for helping...
I mesure the exact same voltage @ +/- 2 volts for 6N1 Plate. This is not a kit from sillicon ray but it is basically the same, but I have received another schematic than the one from sillicon ray..
I'll try to join the schematic, pardon me if it dont work, i'm new to the forum...
Schematic looks fine so if you follow it as shown, there should be no problem.
If you have confirmed these voltages:
> 19v on 6P3P cathode
then most probably it's a miswiring or the wrong part on the wrong position.
> 19v on 6P3P cathode
- Tubes / Valves
- 6N1 + 6P3P build, need some help.
