Hi everyone,
I`m starting a Audio Note Conqueror like 300B stereo power amp project:
http://www.wiatr.republika.pl/schematy/Images/conqueror.gif
I`ve never done any circuits with 300B tubes. Want to order a custom SOWTER mains transformer with such secondaries:
Secondary 1: 425-325-0-325-425@0.25A (B+ 300B/6SN7)
Secondary 2: 3.15-0-3.15@2A (2x6SN7)
Secondary 3: 5@3A (5U4G)
Secondary 4: 7.5@2A (300B)
Secondary 5: 7.5@2A (300B)
(325-0-325 in case to switch for the 2A3 tubes)
Any comments would be greatly apreciated. The transformer makes 1/3 project expenses. Would be very dissapointing to get it wrong.
Since you plan to spend on custom transformer, please use choke-input power supply design. 300B sounds MUCH better like this. Sowter make a good choke specially for this kind of design.
For choke input filter, need 450-0-450 or 475-0-475 for a good design to give about 400..425Vdc for the 300Bs. adjust the voltage with a small (220..680nF 1500Vdc capacitor (LCR capacitors PC/HV/S series) placed after the rectifier, before the choke.
Better still, use 0-475V and a hybrid bridge of UF4007 x 2 silicon diodes and damper rectifiers (6CJ3 etc etc) or 0-490V and uf4007 x 2 and 5R4GY valve rectifier. Hybrid bridges sound superb and make better use of the transformer winding space. Do a search on 'hybrid bridge' to find lots of design tips on these.
Also, do not put 300B filament windings on the B+ transformer. If you do, rectifier noise will couple through to the 300B filaments and injure the sound. Use a separate transformer. And, you will also find that AC heating of 300Bs sounds really bad compared to proper current source heating. for DIY current circuit, see:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=38248&perpage=30&highlight=&pagenumber=2
