Well, I posted a thread regarding a couple tubes that I did not know what to do with, but I think I came up with a idea. Now I just need some professional help. It is focused around the 2c22/7193 tube. Similar to the 6sn7. I have attached a schematic I found on Bob Danielak website for a small power ampifiler. My first question is what do you think? And what would be a good primary on the output transformer. Think I could use a 125ESE? Thanks for the help. I have a case of these tubes and I need to build something with them. Driving me crazy...
kappajoe
If imagine does not work
http://www.geocities.com/bobdanielak/se6sn7.gif
kappajoe
Why not go for an OTL style deal with the 6SN7?
I've seen designs using a variation on the futterman style.. lemme look..
eg. http://hem.passagen.se/ebcpecz/Tube/Headphone/images/amp_schematic.gif
you could use a different tube for the gain & splitter. If you used a split (+/-) supply, you could get rid of the output cap(s) as well.
I assume it would like a little higher than 32ohm though. I think ive seen other designs (srpp), but that might just be my brain going funny ;-)
