FS: NEW Saburo full range backloaded horn custom-made cabinet
Selling a project speaker that I intended to use as a center channel in a home theater setup. Custom made Saburo design professionally fabricated from 3/4" high density baltic birch ply. Wired with a quality Cardas speaker binding post. Faceplate machined to accept Fostex FE-126En driver.
Specs:
71x18x7 75lbs
Paid $650. Reduced to $275
Due to weight I prefer local pickup in DFW but willing to meet within a hundred mile radius to connect with buyers in Austin or Houston etc
Specs:
71x18x7 75lbs
Selling a project speaker that I intended to use as a center channel in a home theater setup. Custom made Sachiko design professionally fabricated from 3/4" high density baltic birch ply. Wired with a quality Cardas speaker binding post. Faceplate machined to accept Fostex FE-126En driver.
Specs:
71x18x7 75lbs
Your pics looks like the Frugal horn, the Sachiko is a double mouth horn w 8” driver.
Thanks you're correct, not Sachiko , its a double mouth Saburo design. Listing corrected.
The last 3 pics are the Frugal horn speakers which are now sold.
