Massdrop CTH+SDAC headphone tube amp and dac for sale in excellent condition. $190 + shipping
SPECS
DAC Section
Massdrop x Grace Design
DAC chip: AKM AK4452
Audio formats: Up to 24 bit/96 kHz
Frequency response, 20Hz–20 kHz: +/-0.02 dB
THD+N at 20 Hz -0.15 dBFS: 0.0013%
THD+N at 100 Hz, -0.15 dBFS: 0.0013%
THD+N at 10 kHz, -0.15 dBFS: 0.0024%
IMD CCIF, -6.03 dBFS, 19/20kHz, 24/96k: 0.0005%
IMD SMPTE -6 dBFS, 24/96k: 0.0015%
Noise, A-weighted: -105 dBu
Dynamic range, A-weighted: >114 dB
Linearity, -90 dBFS: -0.07 dB
Crosstalk at 1 kHz, -10 dBFS (3.5mm jack): -102 dB
Sum of jitter components at 11,025 Hz, -1 dBFS: -133 dB
Maximum output: 2.15VRMS
USB controller: XMOS XU208-128-TQ64
Input: USB micro
Output: 3.5mm TRS
Power: USB Class 1 (no drivers required for Windows, Mac, or Linux)
Amp Section
Massdrop x Alex Cavalli
Frequency response: 20 Hz–20 kHz, -0.2 dB
Maximum power, 50 ohms: 1W Rms per channel
Output impedance: < 0.5 ohm at 1 kHz
THD: < 0.008%, 20 Hz–20 kHz 1 Vrms
THD: 0.0014% at 1 kHz, 1 Vrms with 50R load
IMD: 0.002% CCIF 1 Vrms
SNR: -97 dB, 20 Hz–20 kHz (1 Vrms into 45 ohms)
Crosstalk: -85 dv at 1 kHz
Topology: Capacitor-coupled tube hybrid using 6922 tube, single-ended
Gain: 8x (12 dB)
Input: RCA
Output: 4-pin XLR, ¼ in (6.3 mm) TRS headphone jacks
Protection: Delayed start with muting relay and DC offset detection
Power supply: Wall wart with 28V DC 1.25A
Power consumption: Maximum 35W (28V, 1.25A), ~9W idle
Physical
Chassis material: Anodized aluminum
Dimensions: 8.3 x 9.1 x 2.2 in (21 x 23 x 5.7 cm)
SPECS
DAC Section
Input: USB micro
Output: 3.5mm TRS
Amp Section
Gain: 8x (12 dB)
Input: RCA
Physical
