Still looking. Thanks!
Triode Electronics online has an extensive list of in-stock transformers.
I have used toroidy SE transformers in a pair of experimental amps using 6s4s and 6p15p ~4W with good results, expected lots of rolloff, but they beat very well into 30 hz and up to 15 khz with no visible signs of core saturation their catalogue is fair between 600ohm (6S33S, 6AS7) and up to 7K for GM70 based proyects.
Thank you. If you look at and read the post, your response is a little redundant.
These are tough to get in the US. Plus, shipping would take about as long as Edcor.
I’ve wanted to try these though.
Indeed, but have you looked at their offerings?
