A home-made Single Ended Stereo tube amp.
It uses two single-ended 45 output tubes, driven by 5965 driver tubes.
Tube rectifier is 6CA4. That is all I know as far as technical part of it. I am not the builder and do not have any other info. Output transformers are from vintage unknown tube amp.
The amp is sounding nice and running quiet. High efficient speakers must be mate with as it only put out about 2 watt per channel. It has volume control so you can simply hook up with DVD/CD player and play without going through a preamp.
$600 shipped in the US.
