I've been a huge fan of Ian's project since I came across it in 2013. I've got a few bits and pieces left over from the project:
**SOLD** 1 x FIFO 1.0 kit selling at 65gbp
Including:
- A finished and tested I2S FIFO Board v3.8
- Two 8" single-ended PH 2.0mm 7-pin I2S cables
- One 2" double-ended PH 2.0 mm 7-pin I2S bridge cable
- One 6" double-ended U.FL cable for MCLK
- One 2" 10-pin FPC/FFC cable
It's the left-most item here: http://www.diyaudio.com/forums/grou...2s-s-pdif-fifo-kit-group-buy.html#post2919992
**SOLD** 1 x Dual XO Clock board v3.3 selling at 30gbp
Including:
- An assembled and tested Dual XO Clock Board (double-sided SMT mounting)
- One 6” double-ended U.FL coaxial cable
- One 2” 10-pin FPC/FFC cable
I have modified the clock board in two ways:
1) to run at 3.3v (please see this post here: http://www.diyaudio.com/forums/digi...mate-weapon-fight-jitter-275.html#post3485233 )
**NB - you will need to use an isolator card in order to use this modified clock board. Please see point 3 in the above linked post**
2) I have added another set of output u.fl sockets to allow a second DAC board to be added for dual mono (the additional sockets are SD, WS, SCK and MCK)
1 x Si570 single clock board v3.5 selling at 50gbp
Including:
- 1 power lead
- 1 3.3v jumper
**SOLD** 1 x SPDIF interface board selling at 55gbp
This is brand new in sealed anti-static bag
This comes with a few cables etc as you can see here: http://www.diyaudio.com/forums/grou...-pdif-fifo-kit-group-buy-188.html#post4357477
If anyone is interested in this then I will see if I can find the connectors.
Also, if I can find them I will include the original oscillators that Ian included for testing, namely:
with the dual clock board - 22.5792 MHz and 24.5760 MHz oscillators
with the FIFO board - An 11.2896 MHz oscillator
This can get pretty complicated unless you are familiar with Ian's project so please email post questions and I'll do my best ;-)
Postage will be done at cost (and likely to be pretty reasonable as all of this can be posted as a letter). I accept payment by bank transfer or paypal + fees.
Thanks for reading.
Including:
Including:
Including:
- 1 power lead
- 1 3.3v jumper
Thanks for reading.
