I have two very big heatsinks for sale. dimensions are 500 x 495 x 85
With a massive 20mm mounting base.Weight is +/-20KG. I don't have any thermal specs of the heatsinks because they are custom made. I guess that you can put several hundred watts in it. I prefer that you pick them up at my house in holland !! Price ?? Give me an offer that i can't refuse . fore more pictures please mail me.
Jaac said:I have two very big heatsinks for sale. dimensions are 500 x 495 x 85
Master Scavenger Jacco is certainly near you......
Hi Jaac. It's difficult to email you, because i don't see any button below.
I'm very interested, but it's a heck of a drive from my place to yours Do you think it's possible to send them ( to DK )via mail, without having to pay the price for half a spacecapsule ?
Best regards
Ebbe
Re: Re: Very Big Heat sinks fore sale
email button enabled for denmark it will be around € 32,45 per heat sink for shipment only. i also found a courrier that will do it for 15,95 euro per heatsink but i don't have any experience with those guys.
http://www.gls-netherlands.com/
gr Jaac
and for jacco turn left here
Best regards
Ebbe
gr Jaac
Re: Re: Re: Very Big Heat sinks fore sale
Oh well, i'm not surprised, they are quite heavy. Unfortunately she who must be obeyed think it's more important too eat, so i guess i have to dream on
gr Jaac
es44 said:dream on
You must dream a lot about high performance blower heatsinks ?
These heatsinks have closely spaced cooling fin inserts, pressed into the base plate.
Jaac's thingies are likely in the 0.01C/W range, but are commonly operated as ducts with big MF high volume radial fans that will huff and puff and blow your little house down.
Only good for Odio if you slice 'm up and don't mind stacking fans on the beauts.
Understood, the shooting range is there, i'll turn right if i make it past the car-bar.
It looks like a forged heatsink, fins and base done in one process.
4fun said:Hi,
On the contrary. I think it's quite clear from the photo, that the fins are pressed in that 20mm base.
4fun said:a forged heatsink, fins and base done in one process.
No can do, and usually not a single process.
Ok, I stand corrected.
Maybe size and the long continuous fins should have told me otherwise.
The heatsink just reminded me of a small cold forged heatsink I happen to have. Bonded fins is probably right.
Cloth Ears said:jaac,
What are the fin dimensions? Looks like 1mm fins with a 4mm gap? Fins are maybe 75mm long? 100 fins on each sink? Yes...no?
1mm is too small i guess i will measure it tonight. I sill guess that the heatsinks can dissipate a lot of heat.
gr Jaac
fins are 1 mm and also 4mm spacing and 100 on one sink.
