Hi!
Does anyone know how to sim a stepped horn? I’ve tried with hornresp, but it doesn’t seem to have a stepped horn option. I want to try designing a mini scoop but avoiding weird angles when folding the horn, just to keep it simple. There seems to be general agreement that mini scoops are just bass reflex designs, so I thought that going for a bass reflex with kind of a laberynth port with different vent widths / stepped horn should’t make a big difference on low end and SPL vs. going for a normal horn.
Thanks in advance!
Thanks in advance!
Should be able to get the information you need from this thread:
The collaborative stepped horn project
Something like that ???
Stepped segment is activated double clicking on one of "S1" to "S5" on main input screen. It only work using Tool=>loudspeaker wizard. Not using Calculate button.
Yes!!! That's what I was looking for!!! Thank you very much!!!!!
I'll check that thread too!
Just to clarify - the stepped segments feature originally only worked with the main Input Parameters window Calculate button, but the functionality was later changed so that the feature also worked with the Loudspeaker Wizard.
