I had an old Bose AM7 Series II 8th order BP bass module by me a few weeks ago, and I performed some FR measurements. I suspect that the FR is affected a bit by the age and condition of the bass drivers, but still, it looks like a pretty wide passband for a bandpass system. Has anyone here built an 8th order BP system, and if so, were you able to achieve a similar wide bandwidth?
Of course the wide bandwidth does not come without a penalty - GD for the module peaked at 23ms at around 53 Hz, but still...
not built one but interested - would you say that's a good two octaves ? my old series BP from years ago with 1.2 CF per chamber did pretty well and was used passively to augment some Control I mini. Outdoors and a meter or so away, the graph looked more :"sway backed" than this near port graph
GM - if front chamber depth of K15 were reduced , the how around 250 would probably look more like like
that of my K18. Karlson used a front deflecting shelf in K15 which helped but didn't put that feature into
any of his small "couplers"
here's a beat K15 with the 1954 40.5 sq.in. port outdoors vs a reflex the size of its back chamber - both ~
on cabinet center axis. K15 on sine loaded well to 37Hz (why? - its tuned more like 47)
I imagine PWK used a K33 for the graph of his K15. K33 is an anemic sounding
driver in K15 vs an Altec 421. K33 has a lot of xmax - not needed for K15
Yes, but in fairness it was not the sturdiest design. It was only for fun at the time Dayton PC83-8 (3") test results
I was impressed at what I could get from a couple of small full ranges. It was lumpy, and very tricky to adjust tuning. I would build another if/when I get chance, only it would be a serious attempt.
An adventure with 8th order BP
I have built several 8th order bandpass boxes.
Here with both simulation and measurements.
- Subwoofers
- 8th order BP bandwidth
