note from PWK 1985 re: T-S paraneters
Old 6th August 2018, 09:57 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default note from PWK 1985 re: T-S paraneters
I don't currently have a scanner but will get a scan. I asked PWK about T-S and here's the content of his reply
PAUL W. KLIPSCH
President
May 1, 1985
Dear Mr. Ireson:
The Thiele parameters apply to direct - radiator speakers (closed box and bass - reflex) and not to horns.
If you put a wrong driver in a KLIPSCHORN you will not get acceptable response.
Sincerely,
Paul W. Klipsch
Old 6th August 2018, 11:47 PM   #2
Brian Steele is online now Brian Steele  Grenada
Better not tell David that - Hornresp uses t/s parameters to sim horns, LOL.
www.diysubwoofers.org
Old 7th August 2018, 04:16 AM   #3
freddi's Avatar
sssshhhh - we'll be quiet and he'll never know that doesn't work
Old 7th August 2018, 08:25 AM   #4
David McBean is offline David McBean  Australia
PAUL W. KLIPSCH
President
May 1, 1985
Dear Mr. Ireson:
Sincerely,
Paul W. Klipsch
Hi freddi,
Fascinating stuff - thanks for posting!
It is interesting that in May 1977, Don Keele, working for Klipsch & Associates at the time, presented an AES paper entitled "Low-Frequency Horn Design using Thiele/Small Driver Parameters" :-).
Kind regards,
David
www.hornresp.net
Old 7th August 2018, 08:36 AM   #5
Hi Brian,
Just to clarify - Hornresp does not actually use T-S driver parameters in any of its simulation models (horn or direct radiator). It uses the traditional electro-mechanical parameters Sd, Bl, Cms, Rms, Mmd, Le and Re, as shown on the input parameters window :-).
Kind regards,
David
www.hornresp.net
Old 7th August 2018, 03:04 PM   #6
GM is offline GM  United States
GM's Avatar
Yeah, all those [embedded] specs the pioneers used, but according to the folks that worship at the alter of T/S somehow concluded that they were clueless before T/S.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th September 2018, 05:28 PM   #7
freddi's Avatar
here's a scan of that note. IIRC, I once had another note from PWK where he poked some fun at "T-S parameters" - perhaps like he didn't know what they were
Old 11th September 2018, 10:01 PM   #8
Yeah, but they're all directly related . Hornresp will actually do the conversion if the driver's t/s parameters are provided on the "Input Parameters" screen after double-clicking the "Sd" field.
Old 12th September 2018, 07:04 AM   #9
The parameters are related, but the ways that the simulation models work are quite different, which is the point I was trying to make originally :-). One obvious difference is that traditional T-S models do not take Le into account.
www.hornresp.net
Old 16th September 2018, 12:16 AM   #10
whgeiger is offline whgeiger  United States
Default No Button!
TS parameters are derived form measurements of low frequency, small signal driver performance. To arrive at an optimal match between horn and driver parameters to fill a particular acoustic mission requires evaluation of much more. How you characterize driver performance does not change the quality of the design effort so long as such is used appropriately. I find PWK's brevity amusing. WHG
note from PWK 1985 re: T-S paranetersHide this!Advertise here!
Engadgets flashback to 1985 Dude111 The Lounge 1 6th July 2013 02:37 PM
Bought a 1985 Sony cdp-302 Robcrx Digital Source 5 7th January 2013 10:51 PM
RGB Imput on 1985 Sony KV-25XBR Trinitron TV...what does it do? form109 Everything Else 6 1st December 2011 03:59 AM
1985 Yamaha r8 receiver tresch Solid State 0 17th February 2010 04:28 AM
JL Hood schematic circa 1985? pmkap Solid State 5 18th July 2003 05:29 PM
