Eminence 8" High Excursion DVC Subwoofer 4 Ohm Per Coil
Hi I'm wondering if this subwoofer would be suitable to run in place of the factory open baffle 8" sub in my Honda's rear dash? Factory is something like 40 watts.
I'm not looking to go to bass competitions or anything lol, I'm an adult. I know a lot of mobile audio questions on these forums get the "mobile audio speaker" response or that it's not big enough.
I'm looking to find out if specs wise this speaker will work in an open baffle (infinite?)setup
How the driver behaves during over-excursion (e.g. does the voice coil slam into the backplate, or does the suspension bring the cone to a stop before that happens?) would be deciding factor for me, and that can't be deduced from t/s parameters.
That said, that driver is cheap enough that I'd take a chance on it.
Awesome. Last question for you guys. How much do you think being in an open/infinite baffle arrangement affects the RMS of the sub? The factory sub is rated at like 40watts and it has a pretty good size magnet and looks fairly robust for 40. So I assume I don't need 150 RMS?
This Eminence subwoofer is more suited for closed or vented (or PR) box, not infinite baffle.
For rear baffle choose subwoofer with Qts between 0.7 and 1, and Fs below 40 Hz, like this one:
Goldwood GW-412D 12" Poly DVC Subwoofer
The Eminence model has a lot of motor force for a reasonably priced 8 , but also a terribly high voicecoil inductance (nearly 1mh per ohm of voicecoil resistance) .......
I realize this is going a bit off topic here but it would be great if Eminence could resurrect their old HL10 driver series which had extraordinary motor force and high excursion while still managing to keep the voicecoil inductance (Le) at less than half a mH per ohm ...... They had an incredible achievement there in my opinion ....
The BL2^Re= 90.5 on the HL10 (extremely high for a 10)
I would love to see them come out with a HL10-esque lineup with scaling motors for 8" through 18" cones , such a thing could really put Eminence solidly back on top over the other brands ..
I hope someone from Eminence sees this message
If you insist on 8" subwoofer, than Peerless 830667 is better option:I thought I wanted low Fs and high xmax both of which are higher on the eminence sub? Also I only want to replace the factory sub
Peerless by Tymphany 830667 8" Paper Cone SLS Subwoofer
Although Peerless 830667 has slightly less Xmax (8.41 mm) than Eminence (11.9 mm), it has slightly bigger cone area (213.8 cm2 vs 188.5 cm2). Total displacement volume (cone area times Xmax) is what really counts.
Peerless also has higher sensitivity, it is louder with the same amplifier than Eminence.
Tang Band 740 is more suited for closed or vented (or PR) box, not infinite baffle.
Jeremy, I have primarily been working with resonant designs so I am no expert on OB systems for sure, but from what i have read about them i was under the impression that higher Qts values are preferable for OB, (perhaps that is why Sonce recommended higher Qts in an earlier post) ...... Maybe an OB fan could chime in on this to confirm that this applies to your situation ....
The Eminence 8 that you originally posted about and the Tang Band 740 look like they were intended for use with Horn Loading or compact vented (Bass Reflex) cabinets, (and maybe some bandpass cabinets, or other quarter wave designs could be made to work with those) ...
The Peerless that Sonce recommended has a considerably higher Qes & Qts value ........
Some of the Car Audio brands produce subs with very high Qts values and tight suspensions ...
Well it's not that I am insisting on an 8" it's that there is a hole for an 8" in the car... I'll take a look at it later and see if a 10" is possible without major modification.
Dayton RSHF and UM 8" have a qtc of .57 and .58.
I asked the same question a couple of days ago. Modeled those IB. F3 of 39hz. Looks pretty good for my Honda or Suzuki sedans.
I'm sure those will bang pretty hard. Just wondering if it will be a big extreme firing into the cab of the car. When do you expect to install one?
- Subwoofers
- Eminence High Excursion 8" Factory open baffle sub replacement? (Mobile Audio)
