Passive highpass filter for bass horn
I used a pair of cascaded single pole RCRC filters at the input to the power amp driving a bass only speaker.
It sort of worked.
An active filter with low pass for the bass to mid crossover and with the horn/vented protection high pass added on will be far better.
If you are using opamps, then four opamps give you a 4pole LR low pass and a 4pole protection high pass.
Two dual opamps would be ideal.
moxlite Thread has lots of details showing how this can be done.
