Hi.
I have been searching, without success, for a simple filter circuit to boost the bass response of a full range speaker.
I have found many low pass filters for subs and active xovers but not with the response curve as below.
I want about 6dB boost @ 12dB/octave from say 150Hz down to 20Hz with a sharp cutoff @24dB/octave. I/O at line level.
Any ideas??
Andy
Any ideas??
Andy
poynton said:
.....about 6dB boost @ 12dB/octave from say 150Hz down to 20Hz.....
Andy
Hi, 4 octaves at 12dB/octave = 48dB. /sreten.
Re: Re: Filter Design to Boost Bass for Full-Range Speaker
Not quite what I had in mind !!!!!
Recently on diyAudio...
Perhaps this little box?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=94808&highlight=
This might not be broadbanded anough
http://www.diyaudio.com/forums/showthread.php?s=&threadid=94808&perpage=10&pagenumber=1
Elliot has a parametric bas EQ
http://sound.westhost.com/project28.htm
Sorry, I think I meant this one
http://sound.westhost.com/project84.htm
Re: Recently on diyAudio...
I have seen this and it is what I had in mind but what is the circuit????
Andy
Andy
tinitus said:
Thanks . This may be useful.
Andy
- Filter Design to Boost Bass for Full-Range Speaker
