Mismatched drivers in output stage - is this a problem?
Thread Tools
Old 23rd November 2005, 06:48 PM   #1
Dave S is offline Dave S  United Kingdom
Default Mismatched drivers in output stage - is this a problem?
I am currently building an amp using a quasi complementary output stage (with Baxendall diode). I have a nicely matched set of output devices (MJ15003), however the drivers are MJE15030 and MJE15031 and have very different current gains - 70 and 200 respectively.
Is this likely to degrade the sound of the amp?
The schematic can be found here:
http://www.users.zetnet.co.uk/avonda...bsPowAmps5.htm
Old 23rd November 2005, 10:24 PM   #2
AKSA is offline AKSA  Australia
David,
I would not have thought so, because the two output circuits are quite different anyway as one is common collector and the other common emitter. These quasi circuits always introduce some asymmetry in the output signal which manifests as H2 but disparity between drivers should not worsen this.
The amps look very interesting. Let me know how they compare to the AKSA!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 24th November 2005, 07:37 AM   #3
Thanks Hugh. After measuring the MJEs, I had a read through Doug Self's papers - he stated that the quasi + Baxendall scheme can give almost as low distortion as fully complementary. However Self does not go into any detail on gain selection to optimise distortion for each o/p stage, he also uses spice simulation to generate his linearity plots thereby completely ignoring the real world issue of component tolerances.
The Avondale circuit is basically the same as that used by Naim with a few tweaks. Naim reputedly select parts very carefully and I was wondering which parts and to what criteria. Maybe they encourage 2nd H distortion by deliberately mismatching the halves??
OT - My family spent 3 weeks in Oz last winter (this summer for us!) visting my brother-in-law and family in Sydney. We went to Heron Island and spend a few days at Noosa as well. We also visited the Blue Mountains where we had an inch or 2 of snow!!
There was a bizarre incident where my kids were feeding a wild kangaroo a banana (indigenous Aussie food!!??) in the snow. A local couple drove up and were amazed by the snow, they had never seen real snow before. They were raving about how it crumpled underfoot and how cold it was - we exclaimed "Yeah, but look at that kangaroo, it's so tame etc etc". They glanced at the roo, shrugged with complete disdain, and got back in the car because it was to cold for them.
I guess it's all down to your POV.
Oz is a truly great country though, think we made a mistake shipping you chaps over there!
Dave
Old 25th November 2005, 04:32 AM   #4
David,
Consider the output stage configuration. The upper stage is comprised of two cascaded emitter followers, driven at close to unity gain directly from the VAS. The lower stage, however, is a CFP with diode/resistor degenerated driver, which ensures the collector of the lower NPN always tracks the driver emitter. This pair too is very close to unity gain.
However, when you look inside the CFP, you see 100% local feedback applied from output through the driver emitter, and the combined betas of both devices - since there are two 180 degree phase shifts - creating a huge OLG with corresponding very low Zout and distortion.
Effectively the negative (lower) output block is a closed feedback loop; nested within the global feedback of the amp. Therefore, since the CLG of a CFP is unity, just like the upper block, the relative betas between the upper and lower drivers are not relevant. In the upper block, the driver is an emitter follower; in the lower, it's a common emitter.
I interpret this to mean that their betas need not be matched. In fact, the output impedance of the lower section would be somewhere around ten times lower intrinsically than the upper section because of the huge CFP feedback factor; but since the entire amp is wrapped in global feedback, it's not too important anyway.
It's worth noting that an asymmetrical Zout from each half of the output stage creates H2 in the interaction with real loads, and this, along with production of intermodulation products, has always been the main criticism of this topology. But to my ears they sound pretty good, so I suspect the criticism is, well, a little academic........
What is important is the stability of the CFP. At switch on and switch off, this configuration is generally not very stable and liable to throw up a spray of artefacts. To dampen this problem, JLH added a small 10nF cap across the driver's emitter diode to simulate the capacitance of the base/emitter diode of the output device, and I suspect this is a very good move as it will soften the transitions.
OT: Kangaroos in Oz are a damn nuisance, as on the roads they can easily kill the occupants of a car as they fly through the windshield if struck on the hop. Now snow is a big deal, we so rarely see it, particularly in NSW, hence the reaction of your locals.
I often muse on Britain sending all its thieves and vagabonds to Australia. This left an indelible mark on Australia, giving us a love of equality and a close association with the underdog. It also made us somewhat anti-intellectual, sport loving, and outgoing. However, since we were so badly used by the Brits in the First War and in the atomic tests of the fifties we have become very suspicious of the old country. When we were declared aliens in Britain in 1968 that finished it for most of us. We are strategically important to the US, not to Britain, so our associations are rather faint now even though we still have the Queen as titular head. There is quite a bit of strong feeling about that, too!
You must also factor in that a great many Brits came to Australia as free settlers, including my family (from Lincolnshire, 1843), and since about 1900 this has been an immigrant destination from more peoples than you could name. 60% of the children at my daughter's school are from Asian and sub-continent background!
Hugh
www.aksaonline.com
Old 25th November 2005, 09:37 AM   #5
Thanks for the explanation of the CFP + darlington structure of the quasi complementary o/p stage - it all makes sense when you look at it like that.
I will try the JLH 10nF trick - very crafty indeed!
OT: Interesting comments about Oz and I wholy agree.
Dave
Old 25th November 2005, 10:34 AM   #6
kASD is offline kASD
kASD's Avatar
Hi Dave,
The Circuit is a Naim Clone....I am a huge Fan of Quasi Complementary Configuration...Because in this you only have to search for NPN types for output..indeed which are of low cost and are also available with various specs. to suite your needs...
regards,
K a nw a r
Old 25th November 2005, 11:35 AM   #7
quasi is offline quasi  Australia
quasi's Avatar
Default Very nice
Sexy too. I like Quasi as well ....
I'm also interested in how it goes...
Good Luck & Cheers
Old 25th November 2005, 03:16 PM   #8
Many people who have built it post on Pink Fish:
http://www.pinkfishmedia.net/forum/s...ghlight=NCC200
and reckon it's better than the Naim offerings!
Time will tell.
There is still a niggling doubt about driver selection. I keep thinking about those RC networks between VAS and drivers and how they interact with the drivers transistors.
Dave
Old 25th November 2005, 05:44 PM   #9
Mr Evil is offline Mr Evil  United Kingdom
Originally posted by AKSA
...I interpret this to mean that their betas need not be matched. In fact, the output impedance of the lower section would be somewhere around ten times lower intrinsically than the upper section because of the huge CFP feedback factor; but since the entire amp is wrapped in global feedback, it's not too important anyway...
It may not have a significant effect on the distortion contributed by the output stage itself, but what about the asymmetrical loading on the Vas? This is a large factor in total distortion in the best of cases, but does a mismatched beta increase it significantly or is it swamped by the generally nonlinear input impedance of each half individually?
https://mrevil.asvachin.com/
Old 25th November 2005, 10:34 PM   #10
Mr E,
You are right; in fact there is always asymmetrical loading on the VAS, particularly at the crossover disjunction. Loading from the top of the positive half cycle down is successively high, low, almost zero, low and highish. Swamping the VAS load with a resistor to ground, typically 47K, is a good idea; I notice Michael Bittner did this in his Symasym and I would expect it to be more load tolerant as well since the reactive reflection in the load is less influential in phase shift. However, the downside is that it does cost OLG, reducing feedback factor.
Generally, the Sziklai (CFP) has a greater input impedance than the Darlington, but the asymmetry would likely be greatest as the upper and lower halves hand over. You would expect that the NFB would ameliorate these non-linearities, of course.
But we are wading in murky waters; this stuff is subtle and the psychoacoustic effects of different circuit topologies are not well understood, particularly with all the emphasis on unidimensional parameters like THD.
Hugh
www.aksaonline.com
Mismatched drivers in output stage - is this a problem?Hide this!Advertise here!
Thread Tools
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Mismatched drivers in IB subs mashaffer Subwoofers 1 22nd March 2006 05:56 AM
Slightly mismatched channels lumpylipton Pass Labs 0 26th February 2006 06:38 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
