reduce loudness circult
Thread Tools
Old 9th August 2021, 10:37 PM   #11
HumbleDeer is offline HumbleDeer  Belgium
HumbleDeer's Avatar
The Loudness Comp is supposedly proportional, so another solution to your concern could be to just play it louder
Old 13th August 2021, 07:11 PM   #12
Philip C is offline Philip C
Sorry for my late reply as I was busy with work. The amp now sounds better so far.
I would like to express my thank everyone for their advice on this thread as I have gained much on understanding the circuit.
Last question : What does changing R2501 / R2503 achieve, that is after adding 50 K adjustable resisters after C2503 / C2504.
Best Regards.
Old 13th August 2021, 07:33 PM   #13
rayma is offline rayma  United States
If you have removed those capacitors, the resistors do nothing.
When the capacitors are in circuit, the resistors set the loudness treble level.
  Reply to this post
reduce loudness circultHide this!Advertise here!
Thread Tools
reduce power to reduce heat from UPC1342V kit nine0nine Chip Amps 41 20th December 2020 07:51 PM
Does Valve Noise Reduce if you Reduce Plate Current? primalsea Tubes / Valves 22 14th March 2020 08:36 PM
Can i lower the bias current in the alpeh 5 to reduce power and heat? hifi Solid State 4 7th April 2002 07:48 PM
Reduce difraction and distortion from the cabinet on DIY designs. Bedroc Multi-Way 1 24th February 2002 03:09 AM
Would optical connection reduce clipping? poolguy Everything Else 2 22nd March 2001 08:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
