hi guys ,
i made this amp from a schematic a frnd shared , although i am content with this amp i dont get the crystal clear and airy highs i have felt with other amps also when i tested with square wave everything becomes fugly after 5khz , i have even reduced the miller cap but still the ultra clear highs are not present , does this amp needs a EF3 as my speakers do dip to 2.5 ohms at some frequencies ...
regards
phoenix
regards
phoenix
What are you using for Q8 & Q24 drivers?
I found AX6 dull & lifeless with TIP41c/42c. With MJE15028/29 the highs are fine. As good as the unavailable 2n5320/22 the amp came with, but of which a pair survive. Maybe if you have parts labeled 2sa1837/2sc4793 they are not really 30 mhz Ft parts. My MJE15028/29 are real On parts from Newark(farnell) distributor.
I'd add a large capacitor to ground after D4 and D6. And try without C22.
Are C5, C20, and C21 COG/NPO ?
Unless I'm going blind, where the hell is D4 and D6?
I just don't see them.
Or maybe just get rid of C9, C10. The emitter followers may be OK, as long as they're not "driving" capacitors.
A capacitance multiplier has too high an output impedance to dispense entirely with an output capacitor.
I'd lose the "capacitance multipliers" in the supply rails - they'll probably oscillate.
Could try a simple RC filter instead.
Sorry, don't understand. The capacitance mulipliers are in the supply lines, to smooth the supply to the first stages.
Edit - ah, got it. The ef output impedance doesn't need to be all that low, as the input stages have good psrr. A small C is probably OK, but 100uF is dicey.
Edit2: if there's significant supply droop when the output stages are working hard, the emitter-followers will be starved. Just get rid of the damn' things!
If the input stages have good PSRR (which may be debatable), what were the capacitor-multipliers there for to begin with?
If you need another good reason to omit them, they're costing valuable output voltage swing, too -- could be in the 3 to 5V range!
I'd also suggest raising the VAS current -- 6mA is a little light; 10mA is sort of a *de facto standard*, though I can't give you the reasoning behind it. It might also be worth considering a different transistor. 2N5551/'5401 are rarely found in this duty. I think they'll have trouble keeping up, dissipation-wise.
The bias spreader needs work, too. Right now it only adjusts to about 2,8 Vbe's -- you need 4. Also suggest eliminating R3 and R46 -- degeneration is not good here. Maybe raise the other divider resistor values by x3, x5 or so. That leaves more work for the transistor, which is good since it's a lot stiffer.
Cheers
Cheers
It might also help to split C5 between the VAS transistors. Let Q5 share a little bit of it.
Also agree with earlier poster that 220pF is a very high value. If it's presently necessary for stability, there are probably other techniques/circuit-locations that would exact less of a performance penalty.
Maybe a little degeneration would help Q23 as well. As it is, a very high-impedance node (Q6 / Q16 Collectors) is driving a very low-impedance node, Q23's Base, which gives the 220pF C5 WAY too much influence over the VAS slew rate.
edit: Lower the value of R4. The circuit is designed to set a one 1N4148 Vf drop across it: ~56 ohms will cause a ~10mA current through it. And be prepared for a change in output offset.
phoenix87 said:I have changed the 2n to KSc3503/1381 in the vas stage ...
Good. The C3503 / A1381 pair is a much better choice for VAS service.
Now back to a question asked earlier, "What dielectric flavor is C5?" There are many choices that will decrease sound quality.
Another of those things that I can't give you the reasoning behind: The node R49 - R50 should be disconnected from the output node (the node shared by the four output Emitter resistors). I would suspect that it has something to do with turning off the output transistors more efficiently, since it allows a little bit of negative bias.
Cheers
- help me improve on this current design
