Inkel power amp ARM 1200
Joined 2007
I have one of these in the shed as a spare. I haven't fired it up in several years.
Opening it up it looks very repairable as everything seems discrete and lots of space inside the box.
Dual transformers, 10k smoothing caps and big double die transistors 2SC2774 / 2SA1170.
I need a bit of power for my new speakers and as I know nothing about amplifiers I am wondering if these are worth working on.
My online searching finds very little information.
I can take pictures if needed.
Adding pictures
To my untrained eye it looks like dual mono. From somewhere I have also acquired a pair of the strange looking heat sinks. Somebody has previously opened this up because I wasn't the one who wrapped that terminal in blue PVC tape.
If this is worth working on it will save me buying a new 200 watt amp, provided the rebuild wasn't more than a couple of hundred/ few hundred dollars anyway
