Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
Has anyone tried using a unity-gain "amp" with, say, 8A current output capacity (essentially just a buffer stage) to drive high-efficiency full-range speakers (say, 100db sensitivity) out of your typical DACs with a solid 2v output? I.e., the set up would be just a digital source with a 2v output ==> high-current buffer ==> crossover-less, high-efficiency, full-range speakers.
I am considering using a buffer as way to minimize noise and simplify/shorten signal path. But I am not sure whether the lack of any voltage gain will work in terms of plain loudness and musical dynamics.
Composing music>Playing Music>Listening to music>The equipments you use to listen to music |
#2 |
The 2Vrms output on an 8R speaker would be 1/2 W, and only 1/4 A current.
No need for much of a buffer, it would be voltage limited. You'd likely still need some voltage gain. Last edited by rayma; 20th January 2021 at 06:45 PM. |
#4 |
Thanks. Very informative. I just found out that my DAC has Vpp of 5.7v at full scale output, which appear to translate to 4Vrms. I think I may be in the real low end of the doable zone.
#5 |
5.77Vpp is 2V RMS.
#6 |
#7 |
You are right. Used the wrong calculator and put 5.70v as Vmax instead of Vpp.
#8 |
5.7Vpp renders approx 2.0Vrms. You need a bridge to reach 3.8Vrms.
{ 5,7pp = 2.85p => * 0.707 = 2.0Vrms (sine wave) } several synchro-posts!
Y/Yo=(1-X/Xo)exp2 <> Y/Yo=(e)exp(X/Xo){Xo=kT/q} |
#9 |
If Vmax is 5.7, then what is Vmin? 0.0V? Then it's still 2Vrms.
#10 |
I believe the calculator assumes that Vmin would be negative 5.7v, i.e., Vmax is half of Vpp.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Unity-gain "amp" for high-efficiency full range | mudihan | Full Range | 0 | 20th January 2021 05:11 PM |
Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? | tiefbassuebertr | Solid State | 9 | 9th June 2011 06:49 AM |
Throwing away open loop gain with an opamp near or at unity gain | okapi | Pass Labs | 3 | 25th December 2009 01:23 PM |
Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
New To Site? | Need Help? |
