Classe twenty five DC coupling
Hi
I will get a Classe Twenty five I will refurbish with new caps. As this amp has an input cap which is not needed, I will bypass it. My preamp can be used in balanced mode si I will try it with the Classe. If I bypass C1 in standard use, can I also bypass c9 for balanced mode ?
The input circuit is a little odd.
No leakage resistor to discharge the input cap, no RF suppression cap. Somewhat large resistance values in the feedback and input network, if noise is an issue that's probably why.
DC coupling is perfectly feasible as the feedback network gives unity DC gain, but if you are worried about C1, you'd also worry about C9? You might worry why C1 and C9 have different values.
Its a differential stage with matching networks, the imbalance cannot be more than a few tens of mV as it consists of the Vbe mismatch of Q2/Q3.
One argument against DC coupling is if the source isn't well behaved, it could either trigger the power amp protection circuitry or cook the speakers. This is why AC coupling is nearly always used in commercial amps, to avoid getting a bad reputation for failures that may not be your fault.
Hi
You mention that the input cap. is not needed. While the schematic you posted doesn't show the ouput stage, I feel 99% certain there is no DC servo. Which means that, as others in this thread have pointed out, that 100uF C9 reduces overall gain to unity at DC, which means it will not amplify DC. However, it would pass any DC at the input to the output if it weren't for input cap. C1. Removing C1 would be risky for your speakers.
If you want to experiment with the C1 and C9, I suggest swapping them with some other type caps. Of at least the same voltage and capacitance, but do not operate you amp with either of those caps. removed from the circuit.
Disabled Account
Joined 2017
A few millivolts difference between Q2 and Q3 will be amplified with open loop gain, only to be adjusted with the feedback loop on the imbalanced differential stage of Q2 and Q3.
This yields into overall inbalance throughout the circuit, to have this same amount of millivolts on the output terminal.
It's awfully risky to eliminate those capacitors, especially C9. If you eliminate C9, then the amplifier will have full gain at DC. I predict disaster.
The pole created by C9 and R5? (I can't see it) should be lower than the input pole; ideally by a factor of ten. Haphazard stacking of poles can contribute to capacitors impinging on the sound. When the circuit is designed properly, the capacitors will have absolutely zero effect on the sound.
Disabled Account
Joined 2017
This amplifier is a balanced input configuarion (as used in pro equipment).
This is given by R1-R2 and R8-R15.
C5 is 5u in combination with R2 (113k): Fo= 0.28 Hz
C9 is 100u icw R8 (3k83): Fo=0.42 Hz
If you bypass the caps, you will create a perfect instable amplifier, if not a shortwave transmitter @ random frequency.
Keep the patches and icecubes at hand.
