Advice for improving professional vintage GDR power-amp
Old 17th July 2019, 03:39 PM   #11
franzm is offline franzm
Originally Posted by sgrossklass View Post
Besides, no idea what R8 is supposed to accomplish - some sort of failsafe in case R13 burns up?
Philips patent.
Old 18th July 2019, 12:07 PM   #12
seasound is offline seasound
Thank you sgrossklass (and franzm), my tech told me that
he is going to answer here directly soon.
Old 19th July 2019, 02:27 AM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Be careful with the Baxandall diode, it can sometimes cause oscillation in output stage.
Then lower driver will need a cap between base and collector.
I designed a very similar amp and didn't put local decoupling on the power rails.
The first time I turned something off the glitch on the mains blew up the amp.
So maybe 100uf and 100n close to output transistors.
I also found I needed a couple of ohms degeneration between driver transistors and output transistors to stop oscillation.
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
Old 19th July 2019, 07:54 AM   #14
Thank you for this advice nigelwright7557. This could be very helpful.
Old 21st July 2019, 03:15 PM   #15
Sgrossklass, all capacitors have been renewed. At the moment there is the original transformer balanced input which sounds good but has it's disadvantages (impedance problems, distortion). I am going to test an electronic balanced input-curcuit soon.
Also to mention is the completely renewed power-supply with toroidal transformer, high-quality capacitors and fast diodes.
Advice for improving professional vintage GDR power-ampHide this!Advertise here!
AKG K1000 vintage rare Professional Studio Headphones luxury54 Swap Meet 3 23rd February 2018 02:39 AM
Snail Power CA18 Professional Power Amplifier,Blown Fuse & Power Transistors shorted Peter Qiu Solid State 1 10th December 2016 12:01 PM
Need advice -- Improving an old tube amp McQuaide Tubes / Valves 9 2nd February 2014 04:37 PM
FS: Vintage Philips LHH2000 Professional CD Player Set navigami Swap Meet 2 31st July 2010 09:22 AM
Improving Vintage Advents Greg B. Multi-Way 0 9th November 2002 05:03 AM
Copyright ©1999-2019 diyAudio
