Mystery amp identification?
I got this locally. It works pretty good, but probably needs recapped for better performance. Mostly I'm just curious about it. Obviously it wasn't commercial, and whomever put it together was probably involved in radio stuff because the transformer is for radios that need a bunch of voltages.
One of the bigger transistors is a 2N4921. The other one I'm no sure I can get up to take a peak in the same way.
It's almost impossible to take apart. I mean I cannot actually figure out how it was put together in an order... It's like some kinda weird puzzle. But what I can see is that the board for treble/bass/balance has blue TO-39's??? And a bunch of polystyrene caps it seems.
The lamps turn on during clipping from what I can tell.
I'm hoping someone has simply seen it before.
IMG-0611 — imgbb.com
IMG-0606 — imgbb.com
Ah, well then! That was fast.
This one seems to have been running since it was made, but maybe with the light bulb mod for some reason? Was there an article for a bass/treble/balance board?
How did you like it before it blew up?
Thank you for the information.
