KRELL KSA 100 - whats been done here?
Well scott, those old ROE caps are known to drift, and the PSU caps look like they could do with changing.
Just to refresh and not have any future issues so it last another 20 years! Unless you think otherwise? It is almost 35 plus years old at a guess
Whats this forum for scott? For getting help right? First time i have owned a krell and not much information out there with regards to what goes wrong or sonic improvements people have done. Looking for fellow krell owners with experience in doing what i want to try and achieve, the pitfalls and what to generally what to look out for. Do not want to go in blindly just yet.
For example bigman just commented on what he done, which makes me feel better about doing it.
The first things that were recommended to me were:
1) Change the Roe caps
2) Change the Signal wiring for a good quality modern wire. UP-OCC Neotech or similar.
3) Change the massive output caps
4) Give it a clean inside and enjoy.
T
Yes Scott I have an oscilloscope which can also test caps, resistors and transistors, signal generator, DMM etc
Thanks bigman, thoughts on doing the thermal paste on the trannies again? Thinking if I'm going to pull it all apart might aswell do all I can
