NAD 3020i thermistor? Has anyone even seen this before?
Oops, I'm too slow -- 'Mooly' beat me to it ..
Not that my two-cents is any more valuable than these other fine folks ... but I agree
with posts #16, 18, and 19 -- "Follow the Wires" -- (say it while you think of 'All The President's Men'). There's little likelihood that the part is involved in bias of any sort, since it would be extremely complicated -- and foolish -- to try to bias two separate output stages with one temperature sensor. It all but HAS to be a 'catastrophic overtemp protect' sensor, which I'll dredge the schematics for again, now that I'm not looking for a component involved in bias-setting.
Regards, --Rick
I have a theory.
The NAD seems to use series FET switches to mute the pre out section. Could the thermistor act on those to mute or soft mute the audio when things get to hot.
I can't see a thermistor on the poor diagrams I can find on the web but I did find a picture showing the thermistor and it looks to go to the small signal circuitry.
Mooly,
The theory sounds good. The pic you posted shows it -- the leads go right to the tone pot area of the board, which is electrically next to the mute FETs. We're gonna need some better board prints. I've scoured the posted ones and can't find any sign of the thermistor, either.
--Rick
Thanks 🙂
If this is all it does then it will be a case of either leaving it removed or shorting it out with the proviso that we really should see the details before shorting. If it comes down to being 'not open' for normal operation and if we have no details then I would suggest trying ever decreasing fixed resistors, 100k, 47k, 10k 1k etc and see at what point things work normally. Then just fit something significantly lower than the one at which it starts to work and it should be good to go.
Pencil and paper is as quick as anything for making quick notes 😉 or windows paint.
Right, if it works when shorted then you could simple add something like a 100 ohm in its place and then measure the DC voltage across the 100 ohm. Anything below 0.5 volt or so means the current is minimal (<5ma) and shorting should be OK.
bigshuggy,
Since even casually scribbling a schematic can burn up a lot of time, AND pencil eraser, maybe you could just list the 2, or 3, or 4 parts (R602, D601, etc) that each wire connects to, like:
white wire=xxxx, xxxx, . . .
yellow wire= . . .
Then we could try to sort out which part somebody forgot to draw the little dashed-line bracket around -- and/or mislabeled.
When you have time to get back to it, of course . . .
--Rick
Thanks Craig. That looks essentially the same circuit as the 3020i I was looking at but with a fixed resistor replaced by a thermistor.
Shorting that out is 100% OK as it simply turns off Q517
this as far as I've got - hope it's of some use. Apologies if images too big for the forum.
Q516 is that last know quantity form the common schematic so thought that might be a good starting point? Transistor symbols are not accurate - just used for pins...
I think when the amp/ heatsink gets too hot it mutes the signal until it can cool off to a safe temp. If you short across the thermistor I think it will be stuck in mute forever. This is assuming an NTC thermistor, one that decreases resistance with rising temperature.
Craig
This is the same area on the 3020i/3225PE service manual for comparison - where Q517 plus the thermistor are added with a resistor change or two. 'Seems this board is a ring-in 🙄
