Matching Idss of Fets (Is this setup OK)
Matching Idss of Fets (Is this setup OK) Please consider donating to help us continue to serve you.
Old 15th July 2017, 02:55 AM   #1
bOTL is offline bOTL  United States
Default Matching Idss of Fets (Is this setup OK)
Hello
First time using fets.
Please chime in if this is a proper method to get Idss.
I am setting the Vds to 10volts and getting the Idss from the reading across the 1K resistor. All DMM are set to DCV.
DO NOT ATTRIBUTE TO MALICE WHAT CAN BE BETTER EXPLAINED BY INCOMPETENCE. JC/GS bOTL Audio
Old 15th July 2017, 03:19 AM   #2
rayma is offline rayma  United States
For measuring Idss, you must short the G-S terminals together. That's what the "ss" means.
So, only one supply is needed. Make sure that the Vds remains well over Vp, to ensure saturation.
Don't forget device static sensitivity when handling.
Old 15th July 2017, 03:41 AM   #3
Thanks for the reply
G-S are shorted that is where the - of the supply is hooked up the + is connected in front of the 1K resistor. There is only 1 supply, using 2 DMM to measure. 1 for Vds (10v) and the other for the Idss(across the 1k resistor).
So I assume this setup is OK?
Old 15th July 2017, 03:44 AM   #4
Then it should be good.
Old 15th July 2017, 03:46 AM   #5
Thank You For the Conformation
Matching Idss of Fets (Is this setup OK)Hide this!Advertise here!
bias low Id (Id=1-3mA) for high Idss jfet (Idss=10-12mA) yeuclassa Pass Labs 3 29th June 2017 10:54 AM
Looking for high idss 2SK246BL or low idss 2SJ103BL pchw Swap Meet 0 4th November 2016 05:02 AM
What is the importance of IDSS value and matching in amps using jfets davelang Solid State 4 31st August 2013 12:11 PM
LF: J211 & J212 J-Fet (Idss= 16-20) cartman Swap Meet 0 9th May 2012 05:34 PM
My first FET matching dantwomey Pass Labs 4 16th June 2003 01:57 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
