Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
Greetings to everyone,
as some of you already known, I have in the past tried solutions that could make the V-fet amplifier circuits simpler. Especially I want to remember that on this forum I presented the circuits of the BabySit series which in the simplest version use a single mono power supply. As some already known, V-fet, similarly to tubes, need a polarity of Gate voltage opposite to Drain. But, meanwhile with tubes it is often possible to use autobias with series cathode resistance, this practice is almost impossible to use with the V-fet due to the large signal losses needed and a consistent increase in output resistance of circuit in relation to the load resistance, with a value comparable to the latter. This problem is not so much felt in the follower schematic, with source output, where it typically needs a single dual voltage, but if you try to use a common source scheme with Drain output, if you want to avoid unacceptable performance losses, to properly polarize the devices, it is really necessary to have 4 power supplies (with few exceptions). One of these exceptions is to use a Transnova scheme and myself in the past have presented some project with this solution, but I must confess that they have received (wrongly in my opinion) little consideration. Now, I have developed two new complementary push-pull output circuits, designed for V-fet applications and all other Depletion types as SIT, and Depletion MOSFET, which, although configured as common source amplifiers, they need only one dual power supply and not four different power sources. I think a lot of simplification for using these devices. For now I attach the two principle schemes used and then follow some simulations I think interesting. I obviously look at your considerations on this and good V-fet amplifier at all. ![]() Francesco |
#2 |
The one and only
Both of those are interesting and clever. Circuit 1 performanc is easily predicted,
and it is not difficult to calculate DC voltage distribution for #2, but I will be interested in seeing your sim on it. |
#3 |
Hi mos57. Thanks for the new schematics. Please put example voltages for a stand alone N-SIT compound so as to understand the state of conduction of each VFET. Thanks.
#4 |
Okay, i will begin with analysis relative to circuit 1. Please note that this is simulated in class AB condition.
Here I post images for: 1)schematic with voltage node in static condition; 2)Distortion Analysis at 1 W; 3)Relative Distortion numeric value at 1 W; 4)Distortion Analysis at 10 W; 5) " " " 20 W; 6) " " " 30 W; 7)Frequency " and Voltage Gain on 8 Ohm load. P.S.:Not take too seriously this last FR analysis because model of Vfet not contain parasitic caps. It is here to show the GAIN stage in particular. |
#5 |
Here in the following simulation about circuit 2. Also this is a class AB amplifier.
Images are related to: 1) scheme with node voltage 2) distortion components at 1 W 3) numeric value of harmonic distortion at 1W 4) distortion components at 10 W 5) distortion components at 50 W 6) distortion components at 100 W 7) distortion components at 200 W 8) frequency response (in limited sense as above) and Voltage Gain. |
#6 | |
Both schematics show the use of overal negative feedback to each gate plus the interesting biasing scheme in each amp. Is this considered Schade-style negative feedback? if yes will it it augment the inherent triode character of the VFETs and/or alter them. Thanks. |
#7 |
Hi mos57. Please find attached this interesting article by Jim Stricland inventor of Transova.
#8 |
Thanks for sharing - I hadn't seen that one before!
![]() There is also this at LinearAudio: https://linearaudio.net/article-detail/2224 Unfortunately not free, but nevertheless, interesting reading on transnova-like designs. I think there is some discussion on it around here somewhere ... mlloyd1 |
#9 | |
For the R085 at the bottom you have to select the one with the lowest Vgso, in order to better split the VDS voltages of the two devices. In actual realization, even in my scheme, I think I will use the 2 external Vfet with the lowest Vgs voltage and the two internal ones with the highest Vgso to allow a better distribution of voltages. The reason for using two series devices is because the voltage gain is almost double, as shown by the attached results. One second reason is that it seems to me that with two series devices, although this may seem counterintuitive, the higher order distortions seem to decrease, especially the 5th harmonic (this in the range of 1 to 10 watts) but I need more evidence to be definitely safe. To answer the last question, I claim to have not sought either the Schade effect or the negative reaction, because my intention is to maximize the stadium gain. For this reason, I would have thought of using CCS in the future instead of simple resistances, but you also have to check the impact this modification might have on sound. ![]() Thanks much for your document.
To dare for broaden your horizons. Look at my website: www.amplimos.it - Pope Francis: Those who do not live for serve, they do not serve to live! Last edited by mos57; 5th July 2017 at 10:37 PM. |
#10 | |
![]() Regarding the Transnova circuitry and similarities to the circuit proposed here, I hope to shortly prepare an intuitive principle scheme to show how the audio currents go around the two circuits.
To dare for broaden your horizons. Look at my website: www.amplimos.it - Pope Francis: Those who do not live for serve, they do not serve to live! |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thermal compensation for super complementary output stage? | Nikolai Petrenko | Solid State | 22 | 23rd April 2017 12:05 PM |
Super-complementary output stage | alexp0360 | Solid State | 17 | 26th April 2013 09:57 AM |
Quasi-complementary Output Stage question. | Tequilataz | Solid State | 14 | 25th September 2009 02:40 PM |
Aleph1 with complementary output stage | LBHajdu | Pass Labs | 8 | 5th October 2005 06:37 AM |
New To Site? | Need Help? |
