Modify a amplifier to have more power...
To obtening more power from this ampli can i use 2 braces of output BJT? (the BJT are Sanken 2SA1295/2SC3264)
With 85v power supplies can i have about 200w into 4 ohm?
Inserting a resistor ( of the order of 100 R ) between the emitters
of Q7 and Q8 and paralleling that resistor with a capacitor ( of the
order of 1 u ) might be beneficial for the switch off performance
of the output transistors.
By the way, more power in amplifiers is only useful upto a certain ( not so high ) limit. A few clean watts is all that we need.
Best Regards
Selim
Above a certain power level, it is recommended to cascode a BJT output stage for reliability. This depends on the safe operating area of the output transistors, but as a rule using more than about +-60v supplies requires cascoding the outputs for reliability. This was figured out in the early 70s with high powered amp designs -- feel free to tempt fate, but you will be sorry. If you wish to use 85v rails, it is virtually mandatory to cascode bipolar outputs.
The Leach SuperAmp is an online example of an excellent proven output stage design in this power class.
http://users.ece.gatech.edu/mleach/superamp/
Note that this design requires 8 bipolar output transistors per amp. Because Mosfets do not need to be cascoded, they allow the use of fewer output devices per channel (4-6), but they cost more per device.
