A Directory of Apex Audio Amplifiers - Chapter 2
Founder of XSA-Labs
Joined 2012
This thread is an extension of the main Directory located here:
http://www.diyaudio.com/forums/solid-state/292226-directory-apex-audio-amplifiers.html
Another thread was needed since a post is limited to a max of 50 images. Since I felt that it is important to visually be able to see the schematic of an amplifier design in the index, and Apex Audio is so prolific with his designs, we ran out of room on the main thread. I will try to alphabetize/categorize to the extent possible, but may have to resort to serial ordering of when I discover it if I don't have time to maintain.
We will start this thread off with the
Retro Amp 50W Single Supply - added Aug. 14, 2016:
http://www.diyaudio.com/forums/solid-state/236256-retro-amp-50w-single-supply.html
Build by Olafk:
http://www.diyaudio.com/forums/solid-state/236256-retro-amp-50w-single-supply-18.html
Listening impression by Olafk:
Very nice little amplifier .
Built and work. Nice warm sound.
PCB pdf's by Olafk:
http://www.diyaudio.com/forums/solid-state/236256-retro-amp-50w-single-supply-18.html#post3986254
Video of this amp in action (speakers sound a bit tinny so probably not fault of amp):
https://www.youtube.com/watch?v=gFbivge6oVY
F8 (diamond buffer front end latFET outputs) - added Aug 14, 2016:
PCB layout:
http://www.diyaudio.com/forums/soli...ate-fidelity-amplifier-841.html#post4801156tt
No confirmed builds as of 8/14/2016.
FR100 - added Aug 16, 2016, new design not tested as of this date:
http://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier-207.html
Nice layout by Prasi:
http://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier-219.html#post4833070
A3 - added Aug. 19, 2016:
http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-796.html#post4772109
PCB:
http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-836.html#post4799564
First build here:
http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-849.html#post4806080
Preamp - added Sept 4 2016:
DC crowbar speaker protect (powered by speaker cable so can be placed in speaker itself) - Sept 22, 2016:
P30ZF Zero negative feedback preamp - added Oct 7, 2016:
http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-875.html#post4850095
AX11F (FET input, no need for preamp) - added Dec 15, 2016:
Making "place holders" on #11, #21 posts...
Hi xrk971,
Maybe you can also make post #11 (first post on 2nd page) as a "place holder" for another 50 images on 2nd page in this same thread if it works.
Should be good/enough for a while, but as Apex goes on highly productive, then post #21 (first post on 3rd page) as another "place holder" for another 50 images, and so on... :)
:2c:
Founder of XSA-Labs
Joined 2012
Almost all +/-35v amps will work at +/-25v. You just need to adjust some of the resistors that control the bias current into the input stage and VAS as they will be lower than optimal. However, they will sound pretty good. I would say, pick an amp and play with it in LTSpice to get the new setpoints. Or ask Apex Audio to reconfigure it for you.
