A Directory of Apex Audio Amplifiers - Chapter 2
Old 29th June 2020, 01:04 PM   #11
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Almost all +/-35v amps will work at +/-25v. You just need to adjust some of the resistors that control the bias current into the input stage and VAS as they will be lower than optimal. However, they will sound pretty good. I would say, pick an amp and play with it in LTSpice to get the new setpoints. Or ask Apex Audio to reconfigure it for you.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 29th June 2020, 01:44 PM   #12
Hiten is offline Hiten  India
Hiten's Avatar
Since there are many versions, which would be a go to Apex amplifier of more or less than 100w, which is built, tested (may be refined later on) and well documented ?
Old 29th June 2020, 01:51 PM   #13
Got Foam?
xrk971's Avatar
The FH9 has been pretty well liked by all who built it. I have made a version of it with better spec’d parts and superior layout called the FH9HVX. It achieves 100w with only a single output pair of Fairchild MOSFETs. Sound is beautiful and powerful.
Old 30th June 2020, 02:05 AM   #14
Hiten's Avatar
Thanks xrk971.
A Directory of Apex Audio Amplifiers - Chapter 2Hide this!Advertise here!
A Directory of Apex Audio Amplifiers xrk971 Solid State 173 31st March 2020 10:30 PM
apex audio 800 andrewlebon Solid State 9 9th August 2013 10:45 AM
Chapter Audio Couplet Any idea which D-Amp they use? jpetek Class D 2 1st February 2013 09:06 PM
Audio Transducers - would anyone be so kind and scan me a chapter... ergo Multi-Way 6 21st June 2005 04:26 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
