B&K AV5000 help needed
Hi all, just acquired a supposedly working B&K AV5000 5 channel amp. Channel one has a visually blown mosfet and produces distorted sound.🙁
K1058 on the heatsink is the offender. Any ideas on a replacement? Are these matched, 4 per channel? I can only find a schematic online with no bias or offset listings on it.
Should I just pull the rail fuses and be happy with the other 4 channels?
Thank you
Peter
Check the mosfets from drain to source for shorts.
The middle pin is drain and the right hand pin is the source.
If there is just one faulty you can then remove it and try the amp again.
If it then works ok then the driver stage is probably ok and the one mosfet just needs replacing.
Great news! Thank you. Any idea where I could find another K1058?
I do know the one is bad because there is a chunk blown out of it. I'll test the others.
Thank you for that. I do not care for Ebay or PayPal. Stopped using them awhile ago. Futerlec seems to have them, I'll order from them. So, if the others in that channel test fine then I just pop em in and go? No matching or anything? I cannot find the bias or offset settings on the net or in the schematic. Although they are two pots per channel so I'll assume those are for the adjustments. Sheesh, the caps in this things are the size of coke cans, 4 of them..
Thanks for your help.
Peter
Peter
If the others test fine then it should be ok to replace the one faulty one.
You really need the set up instructions to alter the pots.
Just got a response back from Tabitha of Eastern Elite Audio/Video. Apparently handling questions such as these for B&K. Just in case anyone else needs the info.
"P2 is the bias pot and should be set to 150mA. P1 is the DC offset pot and should be set to 0mV +/-2mV."
Peter
