Our webhosting management team is performing a manual backup task at the moment which is causing the forum to run very slow. This situation will also result in double posts appearing.
The slow response time is "normal" given the circumstance and currently the preferential option versus turning off the forum in the meantime. If it gets very slow, we'll put the forum into read-only mode, or maintenance (closed) mode. Hang tight
