Just learn something from Mr.Pass. Simplicity.
Advoid even single transistor, if possible.
So, got this question. If I wanted to get rid of preamp, take signal straight from the CD player, go into 1 volume potentio and direct to aleph, is it possible?
Aleph has gain only 20db (10x). I will be needing gain about 40db(100x).
What happens if the feedback resistors are modified to have gain about 100X? What will be going wrong? Is that distortions will go enormous?
It should work, although you want to adjust the frequency
compensation values.
The Aleph doesn't have much more open loop than that, so
you will be running with little or no feedback, and you might
not quite reach that figure.
And yes, you should expect more distortion.
However if you replace the load resistor off the input diff pair
with a current source, it will give you more gain, at least at
lower frequencies.
Try getting by with 30 dB or maybe a pot on the feedback loop
so that instead of adjusting the volume control you adjust the
amp's gain.
lower frequencies.
amp's gain.
Yes, understand that.It should work, although you want to adjust the frequency compensation values.
If the gain cannot reach 100x while feedback resistors are 100x, is the DC offset still good, or wandering around?The Aleph doesn't have much more open loop than that, so you will be running with little or no feedback, and you might
I dont like this. Loves the normal aleph sound.And yes, you should expect more distortion.
Why is that? I think the nice sound of aleph also contributed by single 392R. You said about "Little 2nd harmonic". Changing this will change the sound?However if you replace the load resistor off the input diff pair with a current source, it will give you more gain, at least at
lower frequencies.
So this is "Do-able". Wonder why it is not popular approach. Input volume pots have their lack, if the volume is set low, the R and C inside mosfets will form LP filter. This idea should be better than having input volume potentio.Try getting by with 30 dB or maybe a pot on the feedback loop so that instead of adjusting the volume control you adjust the amp's gain.
I get impression 40db gain is not a good idea with single aleph design. How about making preamp like the inverting block in aleph-ONO, feed it to aleph power amp, each have gain 10x, while the preamp is adjustable in its feedback (like 1x to 10x). Will this maintain the sound of aleph?
Mr. Pass, what is your personal comparison between aleph and X generation amps from passlab? You have discontinued aleph generation, turning to X generation. So it must be something better with X generation. Or they are different things, but you have decided to discontinued aleph?
I think you appreciate that after you have sold maybe
10-20,000 Alephs, everybody who wants one either has
bought it already or can get it cheaper on the used market.
A 10 year run would be considered very very good.
Every product has an "arc" to its sales, and before we
perceived the decline in sales of Alephs, we had the X
design ready. We sold them side by side for a couple of
years, but finally Alephs declined to about 10% of sales,
so we concentrated on X products.
Sonically the X amps tend to be more accurate and dynamic,
while the Alephs are warmer. Depending on the speaker
you use or your personal taste, preferences could go either
way. I still use Alephs all the time in listening tests.
No wonder my ears prefers alephs. I tought my ears are not right, but here I have the truth from the master.I still use Alephs all the time in listening tests.
How about XA? Are they more aleph or more X?
Another option would be to use transistors with more gain in the front end. The "raw" open loop gain of the front end is approximately 20 dB if I recall correctly. (The back end also provides gain...something not commonly seen, given that most outputs are followers with roughly unity gain.)
A MOSFET with more transconductance or a low beta bipolar would do the trick. Another possibility would be to run two MOSFETs in parallel on each side of the differential--yes, all four would have to be matched. If you jiggle your parts choices correctly, you can set the open loop gain a little higher than it is now, say about 50-60 dB, then set the closed loop gain to 30 or 40 dB. This way you won't be pushing huge amounts of gain that get turned into huge amounts of feedback, hence changing the sound of the amplifier any more than necessary.
However, when all is said and done, you will find that the sound of the amplifier has changed. If you lower the amount of feedback in the amplifier as it is, then it'll probably decrease the bandwidth somewhat and will definitely have higher distortion, as well as lower damping factor. If you follow the path I outlined above, the amplifier will have lower distortion and better damping factor...but sound somewhat more "hi-fi" and less like an Aleph.
Nelson's suggestion of 30 dB overall gain is reasonable, given that you're using a CD player. I wouldn't go so far as 40 dB unless you were using a low gain phono stage. For that matter, 25 dB might be enough, depending on your CD player.
Your choice.
Grey
Your choice.
Grey
From the papers by Mr. Pass, I created my own imagination about what happened. This is amateur imagination, big chance all are wrong.
Why alephs have warm sound? Because the final stage is single ended. Only the bottom transistor sucks little or big current from aleph CCS above. The 1 side action like this will give big 2nd harmonic. This is what create its warm sound. Hot mosfets sure gives its part. Does anyone has made aleph design wholy by bipolars? Wondering what will be the sound like, inspite Mr. Pass said he pities ones who makes cold mosfet amp (or hot bipolars?)
Susy designs are different. They stressed on the ability of susy to cancel each others distortion, so the speakers will experience minimum distortion. This is why makes it sounds clean, because the right and left side of amps will produce exact distortion that cancel each other, in the eyes of speakers.
If we make 2 alephs back to back, like XA backengineered, they will cancel the distortions to each other, including those nice 2nd harmonics. I don't know. What is the sound of this? I think it will be more X than aleph.
Still about the master's design. I liked the concept of folded cascode like in the x100 backengineered. It performs only 1 stage with folded cascode. The second stage is only current booster, formed by complementary N and P, like totem pole configuration. It makes the whole system 2 stages, like the master said. The full swing already in the folded cascode.
If we only make half of susy patent, and take the - from ground, will it sound like aleph? But with greater efficiency.
Every CD-player put my hands on over the last years delivered around 2 Vrms output level at 0 dB. This amplified by 40 dB gives you 200 Volts and 10000 Watts on a 4 Ohm load...
Nelson Pass said:It should work, although you want to adjust the frequency
amp's gain.
As far I'm aware this implies the feedback loop pot is a very
bad idea, at low volume levels the amplifier will almost certainly
oscillate, unless it is compensated for unity gain stability.
For an amplifier with dominant pole compensation if you increase
gain and reduce the compensation capacitor the amount of
effective feedback at high frequencies remains constant,
however for adjusting the volume via the feedback loop you
need to increase the capacitor for unity gain, running it then
at say 30dB gain = no high frequency feedback at all.
X33 (30dB) gain and reducing compensation values with an
input pot sounds the best option to me for direct CD connection.
Its also possible to set the gain and compensation for say X20
(26dB) and have a switch in the feedback loop for higher gain
when its ocassionally needed. This could be a potentiometer
but it would only have say 6dB range, general volume level
control would have to be done elsewhere so a switch is easier.
🙂 sreten.
Hi !
Holger is right. Almost all CD players have 2V on output.
We need rather attenuator not amplifier. Fortunately, I have
yamaha CDX-593 when output signal is regulated and I have connected it directly to Aleph3. If CD model of "lumanauw" has enough small output impedance utilizing 1K potentiometer may be simple good solution. Taking into account that only small part of Aleph power will be utilized by listener , effective signal source resistance visible from Aleph input will be much less than 1K. If we assume that enough output power is 2W/8Ohm ( it is enough for me ) than needed input signal is about 0.5Vp( 1Vp-p ).
CD gives about 2.8p so source signal has to be attenuated about 5 times. Part of potentiometer visible by Aleph input will have about 200 Ohms. It will have no any bad influence on Aleph sound.
Jacek
Jacek
I happens to also think about this feedback pot, instead volume pot. Never tought deeper into the stability issue. But I will try it soon. I will also report the result here.
Why do people make preamp? If the amplification can be done by a single power amp up to 40db, technically we dont need preamp. But how come so much preamp in the market?
sreten said:As far I'm aware this implies the feedback loop pot is a very
The Alephs are very stable, the example being operating an
Aleph 30 with the RCA input and no shorting jumper on the
XLR - input. In this case, the amp is close to unity gain, but
doesn't oscillate (that is, I haven't seen it oscillate 😎 ).
I say try it if you like, what's there to lose?
Wouldn't this imply its overcompensated for its normal gain, and can be "improved" by reducing compensation ?
🙂 sreten.
One other possibility might be to add a (largish) NPN bjt with E to neg rail and C to ccs on + rail and output gates and change the active outputs to P channel ( I know, more money ) source follower? I understand that this will take more drive current because of swinging gate capacitance over larger voltage, but I think the 9610's could drive a med sig bjt to put out half amp or so. This is a radical departure from Aleph as we know it, but you still have single ended aleph modulated ccs, just more traditional 3 stage topo.
Be easy on me, I read Randy Sloan's book and am trying to see other options. Let me know why this one sucks with a hint of mercy.
lumanauw said:I happens to also think about this feedback pot, instead volume pot. Never tought deeper into the stability issue. But I will try it soon. I will also report the result here.
Only one reason I can see that people do not utilize "passive"
preamp but bulid active preamps ( of course only for connection to CD only ) lays in output impedance of CD and input impedance of power amplifier. Input of Aleph3 for example is RC
connection where R is about 1K and C is aproximately IRF9610 input capacitance ( about 170pF). Thus output impedance of source should be less than it so that do not degrade signal.
On the other hand source shouldn't be loaded to much but it depends how source output is implemented.
Jacek
sreten said:Wouldn't this imply its overcompensated for its normal gain, and can be "improved" by reducing compensation ?
It might, but the Alephs have such low open loop gain and
such simple paths that the compensation we use more often
is employed to deal with parasitic (local) oscillation, as in the
example of Gate resistors on the Mosfets or a cap across the
bipolar transistor that controls the positive current source.
Nelson Pass said:[BIt might, but the Alephs have such low open loop gain and
bipolar transistor that controls the positive current source. [/B]
Sorry to be a pain but its you that originally suggested compensation
needs adjusting for higher closed loop gain which led me to surmise
that the compensation is related to closed loop gain.
From what you say above compensation shouldn't be adjusted.
🙂 sreten.
sreten said:you that originally suggested compensation
needs adjusting for higher closed loop gain which led me to surmise that the compensation is related to closed loop gain.
No, I said the amp would probably be stable. Square wave
could probably use some adjustment up around 50-100K.
Actually, I always stick the phrase in about adjusting
frequency compensation - it's sort of a boilerplate warning.
Why not just change the gain at the DAC in the I-V stage that works great. If your DAC using a BB part, the I-V amp has about a 2.5K resistor change that to about a 3.43K. I have done this on several of my DAC when using a passive preamp.
Remove the Rf resistor and parallel a couple of resistors so you can change the circuit gain. 😉
- Aleph with 40db gain?
